Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: PC Noise
    Jan 2003
    PC Noise
    Have an epia800, and have to sound out hook to my Amp with RCA cables. Problem is there is alot of noise, sorta buzzing sound. I think it might be from the HDD, but not positive. Do notice that if I move the mouse the noise increases too. Could it be grounding issue? I have my dvd rom & hdd both grounded to the board.
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    ground your computer case/PSU to the same spot as your ground your amp. also if you use an inverter ground that to the same spot
    '98 Explorer Sport
    80% done
    Maximum Bitrate CrazyLittle's Avatar
    Jan 2002
    Oakland, CA
    Jan 2003
    no inverter. I grounded the psu to the same spot as my amp. Right now I have it out of my car and I still have that buzz.
    May 2002
    Albany, NY
    onboard soundcard?
    '98 Explorer Sport
    80% done
    Jan 2003
    yes, onboard sound.
    Maximum Bitrate osirisdon's Avatar
    Feb 2003
    South Florida
    You know I also have a noise. My noise is only when sound is comming from my pc. Its like a static noise from a FM band. Dunno what the hell it is. Everything is grounded out. Although NOT grounded to the same spots, but just grounded. Hmmm I'll have to check it out.
    Jan 2002
    Oakland, CA
    If you're getting the buzz with the computer out of the car, it sounds like you've got a bad cap for your onboard's amplifier, or else a broken sound card chip.
    Oct 2001
    Ontario, Canada
    What PSU are you using?
    Try grounding everything to the same spot.
    What guage wires are you using?
    Where are your RCA cables running? Close to any power wires or near engine components?
    Laptops are notorious for the exact problem that you describe, when the HD gets accessed or you move the mouse you can hear a bit of a buzzing (eh, bad description) noise, but this is due to lack of shielding and/or crappy sound cards. If you can make sure to run all power cables far away, make sure that you have at least 10gauge cables, make sure that your +12V and GND cables are the same gauge, that might help. Otherwise I think that you are SOL.
    Can you record the noise by any chance? Maybe that'll help.
    IN DEVELOPMENT -- '96 Mustang, lilliput with PII/450 laptop, custom DC-DC power supply, 60GB; Garmin GPS; 802.11g; compact keyboard, small graphical LCDs, OBDII.
    Jan 2003
    well the problem doesn't seem to be in the car, cause I get the noise when I take the pc out. Its kinda like a white noise, not very loud, but when amplified, its is very audiable. Heres what I recorded by hooking the output to my desktop and recording it.
    Noise Sample
    I had to amplify it a bit to show what I'm talking about. Its a like a static, white noise. That buzzing is when I move the mouse. Not getting much of the HDD noise as I used to, but then again its not in my car.
    My Car audio setup shouldn't be a problem. All the power cables are 4awg. Has a good ground on the body (same gnd for pc). RCA and pwr cables are a good foot or more apart (our else I would've heard it from my HU)
