Results 1 to 7 of 7
Thread: Bought a pre-build from eBay, Need some Advice
    Jun 2011
    Scotland
    Ok i bought a pre-built custom system from eBay at a reasonable price.
    The specs of it are All on board Itx with built in 800mhz CPU, 80gig hdd, DVD / cd drive and 512mb ram. The actual hardware comes in a By byte double din nano itx case while the screen is a chopped up Lilliput 7" Touch (not sure of model number) inside a bybyte black box-n case.
    There is no instructions on how to install this in my car and all that is provided is the cut cables. I have sourced the PSU cables and the PSU is a PWR-M1-ATX PSU. I can identify which cables are the Battery+, Ignition and Battery-. There is also a pink cable coming out of it which im assuming is the ON/OFF line for the amp.
    The monitor is a similar story, no instructions for that either. There is a black cable coming off the power for the monitor, there is also a white cable which i can't identify and a 9 Pin Mini Din To VGA Header Adapter but no cable to connect it to the motherboard.
    Some images of the parts:
    Hoping some kind person can point me in the right direction of possibly setting this up, as this is my first incar PC i am unsure of where i am wiring it to, Would the wiring loom from where the radio was support the Monitor, ITX PC and the Amp or do i need to find other 12v rails?
    Elsewhere
    Quote Originally Posted by Gary Evans View Post
    I suggest contacting the EBay seller, if you haven't. They should be able to help.
    Although, it does look like a hack job, and some wires were cut. That could be the result of someone wanting to remove the unit quickly and not knowing what they are doing.
    The monitor shell is made by Bybyte.com. You may be able to contact them for some assistance.
    The 9-pin miniDIN plug is a standard cable for either Lilliput or Xenarc monitors, I believe. I am pretty certain I have seen replacement cables available for sale.
    The power harness for the radio should be fine for the monitor, but the rest of the equipment should have dedicated power lines run from the battery.
    It's a safety issue.
    How about the Wiki?
    Jun 2011
    Scotland
    So i should be ok running the monitor off the radio power harness and run 2 sets of cables from the battery, one for the PSU and one for the amp. Is 8 gauge cable enough or to much?
    Jan 2008
    honestly, stuff like this really scares me-- for a fear either that it is stolen, or the person that built it really didn't know what they were doing...
    1. the first box looks like a standard computer case holding some very old hardware--i hope you didn't may much for it.
    2. that bybyte case has some very odd hardware installed in it as well-- i haven't the slightest idea what the diagonally mounted board is in that case-- that is not like any lilliput control board i have ever seen..
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Maximum Bitrate tft_lcd_org's Avatar
    May 2010
    Detroit, MI
    The Bybyte Black Box has an old style CCFL Lilliput 701 in it.
    I don't know if the new style LED monitors' VGA cable will work with the CCFL monitor's SKS cable or not.
    Quote Originally Posted by HiJackZX1 View Post
    This system was supposed to be a quick, cheap throw together that has now exploded into a budget blowing mess.
    Jan 2008
    ^i do not believe there were ever any changes made to that cable. i have a older led 629--the same time that the 701 was still ccfl, and the vga cable is interchangeable with my new 669 screen cables.
    HID retro--100%
    May 2010
    Detroit, MI
    Looking at it further, that might not be a Lilliput monitor. The cable is connected to the LCD controller, not an SKS connector.
    Might be time to do a Rick Harrison and "call in an expert....."
  1. Just bought a transflective monitor off ebay
    By shadoxity in forum LCD/Display
    Last Post: 04-20-2009, 04:54 PM
  2. Replies: 4
    Last Post: 08-13-2008, 03:54 AM
  3. Replies: 20
    Last Post: 05-19-2008, 06:13 AM
  4. Bought 8.4" LCD Touch from eBay. HELP!
    By PaPP in forum LCD/Display
    Last Post: 05-31-2004, 12:28 PM
  5. just bought this on ebay
    By zupanm in forum LCD/Display
    Last Post: 02-07-2002, 11:28 AM
