Page 5 of 8 FirstFirst 12345678 LastLast
Results 41 to 50 of 74
Like Tree5Likes
Thread: Android Tablet FM USB Tuner?
  1. #41
    Feb 2013
    Quote Originally Posted by ibf View Post
    Lingo make a DAB/FM radio for android.
    http://www.lingodab.co.uk/product_iVy.php
    https://play.google.com/store/apps/d...5nby5saW5nbyJd
    Same chip family used in monkeyboard DAB+ radio.
    Wow that looks great, can't believe I haven't found it myself in my quest to seek out an FM dongle for android. Believe me I have searched high and low! Guess their SEO isn't that great or it hasn't found it's legs on google yet. Anyway couple of things, firstly I can't see if it can be powered externally. It has a micro usb, but haven't found a datasheet or anything that explains the device in detail. Second, I'm not sure if the signal would be that great. In their FAQ they have a question "why is my kitchen radio a better signal" A: there is no telescopic antenna
    This tells me there is no option for connecting an antenna and likely not going to hold up in the car environment. If anyone has one and can confirm it would be greatly appreciated. I'd happily just buy one of these if the 2 points above can be ruled out.
    @Lincoln
    This particular board is the evaluation board and the antenna is hooked up to the headphone socket. You can decouple it easily and attach to an external antenna, or the standard breakout board has a separate antenna pin. As for performance, it's actually pretty impressive. That video I made I only had a 6" cable (it was all i had) going from the device to my speaker and reception was perfect. They recommend min 3ft, so 6" and still working isn't bad.
    Also the guy that wrote the Ardurino code said and I quote "Picking up FM stations from a plane flying over Portugal!" hahaha how true that is, who knows! I'm going to take the board out in the car at the weekend and give it a test drive. Will let you know how it goes :-)
    I'll keep that splitter in mind, I was actually looking at this http://www.scosche.com/motormouth-ii...-audio-car-kit as it would also solve the handsfree free issue. I've got tablet talk working and that's great for controlling another phone to make calls, but it doesn't pull the audio across. This could kill 2 birds with one stone, provide the handsfree and auto audio splitter for the FM. At least I think that's how it works, but need to find some more detailed info on it. I hate these sites that don't post datasheets!
    Cheers
    fS
  2. #42
    Feb 2013
    Man! These guys have already got it all there ready to go, but no public availability!! http://www.frontier-silicon.com/prod...e/DOK_App.html
    I was looking at possibility of poaching a venice from a store bought radio as I see some people on other threads have hooked them up to windows car systems. It has a I2C interface (same as si47xx) which could be controlled the same way via the IOIO. But then when you look at their site, they've already built it all. I don't understand why they don't just sell them direct to the public?? All our problems would be solved! LOL
    Oh well keep plugging away I guess
  3. #43
    GUS
    GUS is offline
    Low Bitrate GUS's Avatar
    Jan 2006
    Sweden
    Since I am in Sweden, DAB would work, but it all comes back to the antenna, is it good enough for a car environment, not same as moving while you jog. Usually it doesn't work.
    www.longway.to
    Mina bilar
    Roadtrip to Murmansk
    Roadtrip to Odessa
    20 cylinders, about 650 hk Mercedes
    MB 560SL -86
    MB SL600 -94
  4. #44
    GUS
    GUS is offline
    Jan 2006
    Sweden
    Quote Originally Posted by GUS View Post
    One more thing about the iVy, it basically is a radio unit that you control from you tablet/phone, so you would connect the iVy to your amp. I guess you can still play mp3/Spotify and so on over Bluetooth to the iVy and straight on to your amp.
    www.longway.to
    Mina bilar
    Roadtrip to Odessa
    MB 560SL -86
    MB SL600 -94
  5. #45
    ibf
    ibf is online now
    Oct 2010
    Quote Originally Posted by fridaystreet View Post
    Cheers
    fS
    That is the problem with that unit, you will still have to hack it in order to connect a proper antenna. I was wanting to post that link a while ago but I thought people werent interested as they want a cheap android tablet, adding a radio can get costly. As far as I know one forum member is using the Keystone DAB module to connect to his android tablet via RasberryPi. If I remember well its a guy called dabbler in this forum, not sure if he has got it all working yet.
    Hej
    The quality of the module is the most important. Keystone DAB module are pretty good but I wouldnt say they are as good as the proven Venice module, Venice DAB module are used in real HU and high end Hi-Fi. I dont think I have seen silabs chip use in HU, although the SI4703 is better than the silab USB Radio stick but I dont think they are good enough. You can try it I supposed, but I do know both the Venice/Verona/Keytone module put the my Silabs USB radio to shame.
    If you were to put a radio together might as well use a good radio module such as the Keystone chip or the Venice/Verona. They both have good DAB receiver, the FM is not as good as a proper HU though but definately better than the silabs. Seeing both of you can receive DAB, might as well use DAB/FM module.
  6. #46
    Newbie Contra's Avatar
    Jul 2011
    San Antonio, Texas, United States
    here is what I did, I am just ready for the FM dongle
    https://www.youtube.com/watch?v=k0PDqDzRTi4
  7. #47
    ibf
    ibf is online now
    Oct 2010
    I dont think its available yet.
    The Venice/Verona use UART, you can rip them out of a cheap radio
    http://www.argos.co.uk/static/Produc...er/9119882.htm
    Argos change their value product regularly so you might getting something different. Noticed mine is different to the pics on their catalogue (which is actually the same as the Tesco model but in white)
    Anyway here are the pics >
    1) Monkeyboard
    2) Verona carrier board I made, you cant see the Verona module as its soldered on the bottom side.
    3) Blank Verona carrier boards, top and bottom pics.
    Ill say, you might as well use a good radio module if you want an FM radio. These module does DAB/DAB+/FM/FM RDS so you cant go wrong with them.
    Does the android support USB Audio + HID? if so then I might be able to use my radio board on my phone. I have an HTC x one+ right here but I dont have the cable.
    Good luck
  8. #48
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    here's an idea.
    Belkin wireless USB hub
    develop android app for Belkin from source on github
    develop android app for MitchJS devices
    use MitchJS cable to Directed FM radio
    use MitchJS audio selector
    TruckPC - gutted, being used for test setup
    BoatPC - Update coming this spring
    BlazerPC - PS keeps killing battery
  9. #49
    Low Bitrate Lankin's Avatar
    Jun 2009
    Well well well....looky what I found. Anyone seen this? I check this stuff regularly and feel like it just came out of left field. It's a head unit made by scoche that is controlled through an android app on your phone (this includes FM tuning/presets).
    http://www.12voltnews.com/blog/2012/...s-app-control/
    https://play.google.com/store/apps/d...Ryb2xGUkVRIl0.
    http://www.sonicelectronix.com/item_...-SCDBTA60.html
  10. #50
    Jul 2011
    wow...I think that might be my solution...I am gonna order one in na few days...income tax refund ya know
  1. Android Tablet as carpc
    By barryassheton in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 07-10-2012, 01:47 AM
  2. Another Android Tablet thread...
    By GUS in forum Android Tablet
    Last Post: 06-04-2012, 02:46 AM
  3. Android Tablet / Phone in car
    By mchipser in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 03-19-2011, 12:21 PM
  4. Android tablet or Netbook. Which to get
    By jjohnston in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 02-17-2011, 08:24 AM
  5. Android Tablet
    By SLimp3car in forum Software & Software Development
    Last Post: 08-10-2010, 12:36 PM
Tags for this Thread
