Results 1 to 10 of 11
Thread: Integrating new carpc into 2004 honda accord
    Jul 2011
    I am in the planning stages of building my first carpc and have been reading for hours. I have an 04 accord which I will not be able to remove the stock hu from. The screen will go into the lower cubby. see pic http://i203.photobucket.com/albums/a...malser/CP5.jpg
    1. Should I hook up an amp straight to the carpc using an amp? If I get 3.5mm to rca adapter, how do I plug that into a 4 channel and and a mono sub amp? Or should I use car2pc to the stock hu? Then use line out converter to the amps. If I use the carpc straight to amp, what soundcard should I get, I will have a pci ex-x 16 and 2 pci slots on mobo
    2. The main things I want are gps, mp3 storage and playback, and sirius sat radio, on a user friendly front end. Centrafuse is what I'm leaning towards. Are these components overkill and can I save $ in any areas? I am pretty sold on the ssd as I use them on my desktops, and the processor seems to have a much higher performane than those in the $50 range, and its only 65watts
    ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
    $20.99
    Team Elite 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1066 (PC3 8500) Desktop Memory Model TED34096M1066HC7DC $31.99
    MSI G41M-P26 LGA 775 Intel G41 Micro ATX Intel Motherboard $50.99
    Intel Pentium E5700 Wolfdale 3.0GHz LGA 775 65W Dual-Core Desktop Processor BX80571E5700 $66.99
    OCZ Vertex 2 OCZSSD3-2VTX90G 3.5" 90GB SATA II MLC Internal Solid State Drive (SSD)
    -$40.00 Instant $168.99
    Additional: m4atx psu, bu353 gps, 7" screen, sirius module & usb interface, not sure which version of windows would be quickest to load and be stable in long periods of sleep or hibernate.
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    An important question... Do you plan on keeping/using the HU? That answer will drive your design decisions.
    Jun 2010
    Vancouver, Washington, United States
    If you want to use the OEM head unit to drive audio: you need an adapter to feed PC audio through the AUX/XM port (white one on the back). If your head unit lacks that (there should be a button labeled as AUX/XM) then seriously consider buying one off ebay that has that. You can't remove that unit entirely without rebuilding a climate control system yourself.
    Alternatively, as I am doing, you can feed a 3.5 mm jack to RCA stereo cables and to an amp that can spread thru 2 channels to 4 (the new Alpine amps can do this, for example)
    -Zack
    via Droid Charge
    Jul 2011
    Ryven: what about an amp for a sub?
    I cannot remove the stock hu, although I don't mind it being there and not being used because it shoes temp, time, I can store 6 cd's in it. I wanted to know what would give better quality sound, pc2car, then out the stock hu to a line out conv. Then to amps. Or just pc to amps and if this, then which sound card <$100 is the best option? I am leaning towards just pc to amp but am unsure of exactly how this will work, I have seen some sound cards with rca jacks but don't know what features to look for.
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    Some people have pretty good sound quality using the onboard audio - just pick up a 3.5mm to RCA cable (or a 3.5mm to RCA splitter, and a set of twisted pair RCA cables) and run it to your amp. I've used a USB-DAC, and thought the sound quality was very good. It was less than $100, and you can find them by googling for USB DAC.
    If you want to save some cash, and you have time to experiment, start with your onboard audio and see if you like the quality. If not, then move up to a USB soundcard/USB DAC.
    1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
    Jan 2008
    Quote Originally Posted by jt3110 View Post
    being that the radio needs to stay there, i would run the pc through it. the volume control is going to be a little faster then using the windows volume control, and you will be able to keep am/fm/cd for when the carpc acts up.
    sound-quality wise, you will not have a problem-- yes, it might not be perfect, but you will only notice it unless you read Stereophile magazine, and think $500 interconnects sound reasonable.. but then, you wouldn't be keeping the stock radio in the first place, no matter what functions it controls..
    $20.99
    tray-load designs are not recommended for car use because of the chance that the tray can break while loading a disk. slot load designs are preffered..
    ram:
    in-car, i don't think you need any more then 2gb of ram. if you want to use hibernate, the less ram the better. everytime you hibernate, whatever is stored in the ram is written to the hdd-- the more ram you have, the longer it will take to hibernate.
    mobo/cpu:
    i think the e5700 is a little excessive for most tasks. i personally run a e5200(or is it a e5300?) pentium dual core. my system is built around audio processing which is pretty cpu intensive, and i rarely go above 30% cpu usage.
    windows:
    i still prefer xp, though win7 is slowly growing on me. win7 has hybrid sleep/hibernate, which, my understanding of it is that it can be put to sleep+save the hibernate file at the same time. xp doesn't do this.
    imo, stability has more to do with your hardware/software setup then OS selection-- i do a poor job setting up software, and as such, i have just as many problems within xp as i do with win7...
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    Just a quick note about the Accord audio quality. I also have a 2004 Accord with the MB onboard sound driving a small 400w 4ch Alpine class AB amplifier via an encoder driven hardware volume control.
    I’m still using the existing Accord speakers for now and there is, in my opinion, a 100% improvement in sound quality compared with the (now removed) old Head unit/amp.
    Palm sized ainol MiniPC, 8" Transreflective PRO, Win10, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE.
    Jun 2010
    Mickz has the most completely custom Accord build I've seen on a 7th gen. He was my inspiration for pulling my head unit. Find his build thread. Great stuff.
    -Zack
    via Droid Charge
    Jul 2011
    wow! That is the most detailed car mod I have ever seen. Very impressive
    Ryven, how did you pull your hu, did you use microcontrollers and remove the stock hvac controls like Mickz?
    I think for now I will put the screen in the cubby, especially bc it will have less sunlight reflection down there.
    Jan 2008
    Quote Originally Posted by careboy View Post
    you can use 3.5mm to rca adapters to get the audio out of the carpc without needing something that uses rca connection.
  1. Double Din LCD fitment issue (2004 Honda Accord)
    By ajamils in forum LCD/Display
    Last Post: 03-15-2011, 04:08 AM
  2. 2003 2004 2005 Honda Accord CarPC
    By Adam2312 in forum Newbie
    Last Post: 02-09-2009, 10:25 PM
  3. Honda Accord 2004
    By om4r in forum General Hardware Discussion
    Last Post: 09-10-2008, 08:45 AM
  4. LCD in 2004 Honda Accord
    By skizot in forum LCD/Display
    Last Post: 04-03-2008, 09:45 PM
  5. 2004 Honda Accord Upper Double Din – IVA-W200
    By EricRhinehart in forum Car Audio
    Last Post: 02-10-2007, 02:21 AM
