Results 1 to 10 of 11
Thread: I know it's trite, but please look at my inverter prob =)
    Jul 2000
    Chicago, IL, US
    Post I know it's trite, but please look at my inverter prob =)
    thanks in advance!
    I've got a slim desktop system as an mp3computer, and I'm using a 300w inverter.
    I plugged the computer into the inverter and that into the cig.adapter, listened to music with headphones, and it sounded just fine. Revved the engine, etc, sounded great.
    Now, my car's at the car audio shop, and I now have amps and better speakers in the car. The inverter is hard-wired to the battery, and grounded to the chassis. Apparently (I haven't heard it myself) audio from the computer now sounds like complete crap! I'm trying to get a head-start on this problem before I head to the stereo shop tommorow.
    The computer sounded great when powered through the cig.adapter, and nothing was grounded... now it sounds horrible. Granted, I was using headphones before and now I'm using amps etc, but can that account for the difference?
    Sounds like my first step should be to ground the computer's power supply (it's NOT grounded now) and make sure the inverter is grounded properly.
    I didn't find any other posts with a similar problem... What could cause the audio to sound fine when powered through the cig.adapter, but horrible when hardwired and going to amps?
    Any input is greatly appreciated!
    -Brian
    Nov 2000
    Post
    Well, cig lighter does have a built in ground, but every ground in car is basically the same, so as long as you are positive that the ground you are using now is unpainted, pure car metal, then you're fine.
    You did say one thing scary, your PC is NOT grounded? That's a real big problem. Remember the the power supply gives ground to the PC and all the other parts as long as it is ground (ie, 3 prong). If your PC is not pluged in by all three prongs, you need to ground it...
    Nov 2000
    grandeprairie alberta canada
    Post
    that's most likely the problem the age old commong ground problem if the computer isn't grounded it's not grounded the same as the amps
    Jul 2000
    Chicago, IL, US
    Post
    Thanks guys for your input! I haven't actually been able to look at the situation yet, as my car is in another state =) But I'm trying to get a head-start on the problem.
    I'm almost 100% sure that the computer *is* plugged in w/ a 3 prong plug. Now that you mention it, I believe that the inverter may *not* be properly grounded. It's bolted to the chassis (I hear...) but there may need to be paint that must be removed.
    Any other input is greatly appreciated.
    Hopefully I'll check out the situation tonight and I'll get back to you guys!
    BTW, do pure sine wave inverters exist? Are they *very* expensive? heh...If not, where can I find one?
    Thanks,
    -฿rian
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Cool
    The problem is a ground loop between your computer and the head unit/radio/whatever. Ground the chasis of the PC directly to the car.
    Aaron Cake
    Player: Cyrix 200, 32MB RAM, 10.2Gig Quantum HD, Onboard EtherNet/Sound/Video, Custom Lexan Case, Arise DC-DC, Win95 Kernal w/Custom Player
    Car: '86 Mazda RX-7 w/Basic Performance Upgrades
    Jul 1999
    Greensboro NC
    Post
    I've seen very powerul true sine inverters for use on houseboats before...can't remember exact prices but they were expensive.....but they do exist!
    Jul 2000
    Chicago, IL, US
    Post
    I looked at the car yesterday. It turned out that the metal DB25 sleeve that I used for an extension cable needed to be grounded. It's grounded through the computer... but I guess I had a ground loop? Anyway, Sounds perfect now, inverter is grounded to the chassis, metal cable part is grounded to the head unit. This is the reason that it sounded perfect through the cig.lighter. I'm lucky that that's all it took to solve my inverter problems =) ...a wire came out of my lcd and caused garbled output... but that's another story.
    Thanks for the input guys!
    -฿rian
    moahdib's Avatar
    Jul 2000
    Post
    Brian, so you solved your problem by grounding a DB25 sleeve???? I don't know what you mean by that. Is that a DB25 to DB9 adaptor? or a DB25 serial extension cable?
    I gotta really weird sound problem, when everything is hooked up it sounds great. But as soon as I remove the power connector to my 5.6" LCD the sound is just TERRIBLE!! The power to the LCD comes from the cig adapter and the power to the computer comes from the battery. But as long as the power connector is hooked up to the LCD, the sound is great. i really dont understand why this happens... any help?
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
    moahdib's Avatar
    Jul 2000
    Post
    Honda Civic 97 coupe
    Pioneer KEH-P5700 with modified Aux In on IP-BUS input and remote, 10" Amplified Bazooka, stock 6 speaker system.
    Removeable 5.6" LCD, mounted on dash, custom wood case for PC, AMD K6-2 475mhz,64MB SDRAM, removeable 30 gig Maxtor HD, 6X Slot CD-ROM, Finger Mouse, IRMAN, GPS receiver (RandMcNally), ATI AIWPro 8MB PCI, SB Awe 64 w/ LINE OUT, High Performance CPU Heatsink Fan (used for overclocking), 2 misc +12V fans. 300W Inverter, trunk temperature gage on front dash.
    WinMe slightly modified
    IRAssistant, Winamp, DeLorme RWE, Mappoint 2001, AudioCatalyst mp3 ripper, on screen keyboard, SMR DVD ripped movies, everything controlled by HU's remote.
    Wnamp plugins :
    ALBUMLIST, TIXOFT FONT, AUTOPLAY, ROCKSTEADY
    SEXY ANALYZER, GUEISS, EONIC, and others i can't recall...
    My TL CarPC ver2
    Jul 2000
    Chicago, IL, US
    Post
    moahdib,
    I wish I knew how to solve your problem.
    Just to clarify, I converted a printer cable I had to a DB25 extension cable. Radio Shack sells DB25 connector pins and sleevs, so that's how I fabricated one end of the cable. The sleeve is completely metal.
