Results 1 to 7 of 7
Thread: Power Supply for Testing before Install
    Jul 2011
    In the past, I used an $80 RadioShack 12V AC to DC converter to test my setup before install, but I lost it in my move to LA I had a thought, and already pulled the trigger, so thought it best to ask someone with more experience with electronics.
    Instead of buying another $80 inverter, is it safe to use a computer powersupply for the 12V rail? I bought a 400 Watt PS on Ebay for $19. If I chop a black and yellow cable, thats 12V. What I'm not sure about is how the 400 Watts are distributed.
    Any ideas?
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    Yes, you can use a computer power supply. Just google it - you'll find a few tutorials on how to do it. It's very easy. I use one for my test bench.
    1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
    Jul 2011
    This one is fancy...
    Too fancy. Is it safe to connect my m2-ATX to the yellow and black leads coming out of the PSU?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Yes.
    You will also need to Ground the PWOK wire from the ATX. (ie connect the green wire to any black wire, assuming the ATX has the correctly colour coded wires)
    May 2011
    New Zealand
    I use an Xbox 360 power supply, only cost me $5! =)
    Low Bitrate chris_h's Avatar
    Apr 2010
    VT
    don't use the radio shack variable power supplies. i've had so many customers ruin their products with radio shack's subpar products.
    grab an AC adapter of choice and mate it to this DC jack-to-p4 cable. cut the p4 connector off the end and mate the leads however you want. instant bench tester.
    cheers
    Apr 2010
    VT
    your image is busted
  1. Power Supply Bench Testing Question
    By blackflux in forum Power Supplies
    Last Post: 03-16-2011, 05:33 PM
  2. Bench Testing Power Supply
    By Mears in forum Power Supplies
    Last Post: 07-30-2009, 02:28 PM
  3. Testing power supply output
    By cadence117 in forum Power Supplies
    Last Post: 06-28-2004, 05:37 PM
  4. Testing a power supply to see if good or dead?
    By Squeezer in forum Power Supplies
    Last Post: 03-17-2002, 01:19 PM
  5. Testing an Astec power supply
    By Machs_FueL in forum General Hardware Discussion
    Last Post: 08-28-2000, 04:15 PM
