Results 1 to 10 of 15
Thread: AMD cpu and case questions
    Aug 2008
    SouthernOK
    My luck with Intels has never been good so I've pretty much been using AMD's for desktops. Whenever I search here for AMD here, it comes up empty. So my question is anyone using an itx-amd board?
    Are cases really necessary? The way my setup is right now, is I have my motherboard mounted to a board which slides into my enclosure that holds the screen. Then the hard drive is also mounted to a board and lays underneath the seat.
    My setup is in a F150 using a mATX board and an m2 power supply mounted to the enclosure (everything has spacers so they aren't sitting directly on the boards).
    I've had issues with it for the past year. Now I'm looking at starting from scratch except for my enclosure. Looking at a ASUS E35M1-I Fusion AMD E-350 APU (1.6GHz, Dual-Core) AMD Hudson M1 Mini ITX Motherboard/CPU Combo and trying to decide if I want to try a case this time. I'm not looking to spend alot since the truck isn't a daily driver anymore.
    2004 F150 STX Heritage:
    Parts:
    ASUS E35M1-I Fusion AMD 1.6GHz DC ~$114
    Patriot 32GB SSD ~$80
    Kingston 4GB ~$25
    1/2" MDF - ~$15
    10" Samsung touch panel - ~270
    M2 Power Supply $85
    GPS Receiver ~ $36
    iGuidance ~100
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    I actually just purchased one of those boards for a separate project, but I have been quite happy with it and plan on replacing my atom with one soon in the car. One thing to keep in mind, definently use the included CPU fan. I know it says fanless, but the CPU runs near 50C under moderate load without the fan, and that's inside where the ambient is low. I would definitely get a case though. I've run without a case before, and I always had audio and video noise issues, which a case has solved. Also, with a case you can use directed airflow to help cool components.
    That, and a case makes for a much cleaner looking install.
    RevFE
    My Shop
    Jul 2010
    I use one the fusion boards in my install now. Works awesome so far, but I'm far from optimized. I have 8gbs ram with it, but with 32 bit windows 7. Still cold boots in like 30 seconds, i'm sure it will be faster with the 64 bit windows install. I'm not running a case either, but it is enclosed in a compartment in the trunk. Suv, so it's not a closed trunk, but I don't hear any heatsink or other fans, or hdd either. Overall, I'm very happy with it.
    Current Worklog: TBA - '05 Rav4 (Mobo Dead).
    www.rav4world.com - Forums for Rav4 owners
    www.flavorfeasts.com - Cooking website/forums
    -Basic forums live atm, come contribute!
    Aug 2008
    SouthernOK
    How tall is the board? Should I be concerned about case heights? Some of the cases look rather short.
    Parts:
    Kingston 4GB ~$25
    1/2" MDF - ~$15
    M2 Power Supply $85
    GPS Receiver ~ $36
    iGuidance ~100
    Jul 2010
    I got the asrock board (the cheapie), it has a cpu fan on it. It's really small though, as if I remember right, I don't think the cpu fan sat higher than the mobo outputs on the back of it.. Or, if it did, it wasn't like a normal, big cpu fan, it was barely above them.
    Jan 2008
    ^ now you got me thinking..
    i know for sure that the basic intel 945glcl board has a slightly taller heatsink then the rear i/o ports, but otherwise, all the models i can remember are very close to keeping the heatsink no more then 2-5mm above the tallest i/o port--which means they should all fit in a case just fine..
    Jul 2011
    I looked into the fusion options recently and when I looked at reviews it looked like if you were going to be playing Blurays then the system would be pretty much maxxed and that wouldn't leave much for NAV etc. I don't know how intensive the other programs are but if you're maxxed playing Blurays everything will slow to a halt.
    Jul 2010
    Most of the reviews like this that I read were for htpc uses. Meaning, they probably are doing lots of encoding/transcoding (to get better than the best pictures), sending through networks, etc... I'm sure in a car, the ability to play the normal/average bd rip or bd off a disc it will be more than capable. I don't use blu-rays though, so I'm not sure how it will work in reality.
    Jul 2011
    The one that I am thinking of was just watching a Bluray. If this feature is what you want in your car I would be careful
    Aug 2008
    SouthernOK
    About the only thing I'll be running is music and gps. Never had a need to watch movies in the truck and if I did it wouldn't be blueray.
    Parts:
    Kingston 4GB ~$25
    1/2" MDF - ~$15
    M2 Power Supply $85
    GPS Receiver ~ $36
    iGuidance ~100
  1. Questions about this case...
    By monkeyracer in forum MP3Car Products - store.mp3car.com
    Last Post: 06-30-2007, 08:39 PM
  2. Custom Case.. some questions..
    By VPrime in forum Fabrication
    Last Post: 02-09-2007, 09:52 AM
  3. Ampie case questions
    By ShdwMastr in forum Newbie
    Last Post: 06-14-2005, 12:44 PM
  4. case fabrication questions
    By scuba_steve in forum General Hardware Discussion
    Last Post: 12-27-2003, 01:13 AM
  5. 2 Questions concering Case and DVD
    By CrzyOne01 in forum General Hardware Discussion
    Last Post: 10-09-2003, 05:34 PM
