Results 1 to 3 of 3
Thread: Looking to build something to display multiple sensor data.
    Aug 2011
    I been looking at some how building a device that I can connect to multiple sensors. All these devices are external to the vehicle. No interconnect to the vehicle systems. here is an example of what I am looking at doing. Have a screen display that will show multiple sensors like temperature sensors, pressure sensors of fluid, boost/vacuum sensor and liquid level sensors. Lets say 4 temperature, 4 fluid pressure, 2 boost, 3 level sensors. I do not mind if they can not all be displayed at one time or not. Can be scrolled up or page to a new page. The last item is the ability to use a couple buttons or touch screen to go up or down 5 positions. Each position would activate a relay for that selection 1 through 5.
    If anyone is familiar with say the Edge Products Insight CTS/CS devices it be something like this but just for connected multiple input sensors and some output controlling as well.
    Any help will be great on some I/O boards and programming to do as I would like to do. This be a one of kind project for personal use. Thanks to any and all with input or ideas for this. If someone has the ability to even make this I be interested in your time.
    Thanks again to everyone.
    Newbie theBlueLight's Avatar
    Aug 2008
    Melbourne, Australia
    Is the Fusion Brain not what you are after?
    Variable Bitrate heezer7's Avatar
    May 2004
    IL, USA
    Or an Adruino board.
  1. Display OBD data w/ external sensor data?
    By Gr0nk in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-19-2011, 04:13 PM
  2. Using the data from a fusion brain sensor in another program
    By thecrtographer in forum FB Software
    Last Post: 12-30-2009, 12:30 PM
  3. Recording sensor data.....
    By drk in forum Fusion Brain
    Last Post: 05-01-2008, 01:29 PM
  4. Sensor Data with Java?
    By aLIENKa in forum Coders Corner
    Last Post: 04-07-2008, 02:49 PM
  5. How to modify sensor data?
    By greenman100 in forum Road Runner
    Last Post: 01-19-2007, 05:02 PM
