Results 1 to 6 of 6
Thread: Where to buy dual USB cable?
    Newbie leeman01's Avatar
    Aug 2008
    Pikeville, North Carolina, United States
    Looking for the dual side-by-side USB cable for the nano double din case by bybyte. Anyone have a source to by these from? Also, I believe I need the 2.0mm pitch for the headers on a pico-itx board. They're a bit narrower than all others.
    Lee
    Jun 2007
    Boston MA
    It looks like it's something the motherboard, Via NX-15000G, comes with. Take a look here: http://www.bybyte.com/boards.htm , at this particular image: http://www.bybyte.com/highslide/imag...piaNX3x600.jpg
    Constant Bitrate meryan00's Avatar
    Feb 2007
    Indiana
    You could always just buy regular ones and get this 2.0 to 2.54 mm adapter
    http://www.e-itx.com/acc-usb-254-adap.html
    Aug 2008
    That link isn't for a PICO board. They do not come with but one header adapter. bybyte doesn't sell pico-itx.
    Quote Originally Posted by nivanov View Post
    That adapter may work good though!
    I found the correct dual cables, but still needed the 2.54 to 2.0 adapter.
    Lee
    May 2010
    Moncton, New Brunswick, Canada
    Better to go to the source, bybyte
    Attachment 63302Bybyte, the manufacturer of the double DIN box has them on bybyte.com, cable and adapters, adapters, $4.99 USD (cheaper than Startech).
    If the adapter from 2.54 to 2.00 pitch just reduces the spacing between the pins, you can just unattach the metal connectors in the plastic housing and cut up several plastic housings into single connector housings, 5 individual plastic housings with metal connectors.
    If the pins on pico are smaller than standard boards, you may have to order the connector from digikey etc.
    May 2010
    better site
    go to http://www.e-itx.com/acc-usb-254-adap.html
    2.54mm to 2.0mm pitch USB Port Header Adapter Cable
    $2.95
    Same site http://www.e-itx.com/cab-usb-dual-bracket.html
    Dual USB 2.0 Ports with Full-Height Slot Mounting Bracket with 2.54mm pitch USB connector
    $4.95
  1. Replies: 4
    Last Post: 10-28-2010, 10:24 AM
  2. Intel Dual Video, Dual Audio motherboard
    By wicket in forum General Hardware Discussion
    Last Post: 10-23-2007, 09:36 AM
  3. Dual mice and Dual Pointers
    By ThunderStick in forum Input Devices
    Last Post: 06-17-2007, 07:42 PM
  4. 2.5" ide dual drive cable
    By CoyoteBoy in forum General Hardware Discussion
    Last Post: 06-28-2006, 06:18 PM
  5. My Dual Xeon, Dual Booting System...
    By greenman100 in forum Off Topic
    Last Post: 04-29-2006, 11:08 AM
