^ that is to say, when measuring across the switch terminals.
that is weird. i assume that you were holding the negative volt meter lead to a chassis bolt, and then metering the terminals? also, was that with the switch on or off? try both ways? if so, then that means where wherever that ground wire is attached is a bad ground-- try moving it to where the volt meter lead was attached.
LinkBack URL
About LinkBacks
