Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: 12v rocker works; 12v rocker with ground...does not
    Oct 2008
    Good Evening,
    I finally found someone to make me a custom switch panel for my mustang's center console. Prior to this, I had loose wires with standard 2 prong 12v rockers(no ground prong, no LED).
    Along with the panel, the vendor sent me 12v rockers that include a 3rd ground prong which activates an LED.
    The computer works fine with the old switch.
    The computer works fine with the new switch if the GROUND IS DISCONNECTED
    If I connect the ground to the switch, the computer WILL NOT turn on...(The LED does function though)
    Any ideas as to why the ground might be messing up my situation?
    Here is a link to my current setup for power, etc.
    Over a year later I guess it's true...a carPC is NEVER complete
    2002 Mustang CarPC
    Maximum Bitrate tft_lcd_org's Avatar
    May 2010
    Detroit, MI
    Where are you grounding the switch to?
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    Which prong are you grounding? It sounds to me like you have the switch wired incorrectly.
    1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
    Oct 2008
    Prong 1 is connected to my ignition/accessory
    Prong 2 is connected to the pc
    Prong 3(Gold) is connected to a metal bolt(connected to the body) beneath my center console
    Thanks a million for the replies. Hopefully I can figure this out(not a HUGE deal...but annoying after I spent the $ for a quality looking item)
    2002 Mustang CarPC
    Nov 2010
    Panama City Beach
    The rockers in the pic you posted on your usb thread are the same ones I have. There should be no problem with that switch. Pin 1 is the ground, pin 2 is the out to your pc, and pin 3 is the input from your 12v power source. Looks like the pin is wired backwards. You can test the connections using a multi-meter. Or, if you don't have one, use a 9v battery and some wire and a flashlight lightbulb to make a circuit.
    Oct 2008
    Thanks for the reply. When I stated PIN numbers I didn't refer to the actual switch. This is the switch I have from this actual company. I called the representative yesterday before posting and he had said everything sounded fine and was confused as to why it wouldn't work. I even tried one of the other 2 switches I ordered and i have the same issue.
    How would I test with a muli-meter(Which I do have)? Should I see if the output to the PC is lost when the ground is connected?
    I really appreciate the help.
    2002 Mustang CarPC
    Jan 2008
    yes, testing with the multimeter would be a very good idea.
    Nov 2010
    Panama City Beach
    That is the same switch sold at Autozone and O'Reilly Auto Parts. Connect one lead to pin #3 and the other to pin 2. Turn the meter to ohms. When the switch is closed (the side with the LED pushed down) the meter will read very close to 0 ohms. When the switch is open, the meter will not read any ohms.
    I still think the switch isn't wired correctly - it sounds like you have the ground pin connected to your 12V source, instead of it being connected to the 12V input pin on the switch.
    Raw Wave
    Nov 2009
    Forgive me - just dropping in and very subject to brain farts... (What a night!)
    As I see it, the switch is wired ok.
    If +12V & GND were interchanged, the LED would not light when ON (unless it is bridge rectified which they don't normally do - those switches are maked +12V etc, not pwr in & pwr out and opposite power polarity or equivalent.
    If +12V & the output were not connected across the switch contacts, the pc would not turn on.
    If +12V & GND were across the switch contacts, it would melt/blow (ON shorts +12V to GND).
    Ergo, the switch is wired fine. But please check/confirm my logic...!
    The PC works with no GND connected - as if the 20mA LED is somehow effecting the connection. (Restating the obvious.)
    Check output with a reasonable load - maybe a light bulb (brake bulb ~21W => ~2A, headlight 60W = 5A etc; a dash globe ~3W = 250mA may be a bit low to detect a high switch impedance - not that a GND via a LED sould impact that). A multimeter alone won't detect the ability to suppply high current (it only draws uA).
    The "always connected to PC" LED (20mA) grounds the PC +12V, but that has no effect - ie, it is +12V when the LED s on (unless a faulty (high-impedance) switch), and it's not keeping the PC on when OFF - that is sometines an issue when LEDs etc are connected in OTHER sitations, but not in this case.
    A solution may be to have the switch energise a relay that powers the PC. Though I'd still want to know ytf the 10A reated switch itself doesn't work, I'd normally wire it that way because I'd use a direct feed via a fuse from the battery (as done by most - it's the cleanest power supply) AND I dislike running more than a few Amps through a switch - even 16A rated switches. (I can expand on that if required.)
    In this case I'd just check that the relay coil gets 12V and not something like 8V which can be close to its drop-out voltage.
    I'll check in again after brekky & coffee....
    Jan 2008
    i should add that i have 5 of those switches installed in my car, as well as a green, yellow, and blue led version, and none of mine have any problems.(the green switch is connected in the exact same fashion as yours)
  1. rocker switches
    By mattman in forum Car Audio
    Last Post: 06-28-2008, 10:48 PM
  2. rocker switch hell
    By nomorspam in forum General Hardware Discussion
    Last Post: 07-13-2005, 11:23 PM
  3. Lighted rocker switch question
    By ddt in forum General Hardware Discussion
    Last Post: 05-20-2005, 08:05 PM
  4. reset with rocker
    By supernoob in forum Newbie
    Last Post: 05-12-2005, 01:51 PM
  5. SP3T Rocker Switch
    By Zoltan in forum General Hardware Discussion
    Last Post: 08-08-2004, 09:02 AM
