Results 1 to 7 of 7
Thread: Mounting computer in a trunk
    Aug 2011
    Colorado
    Are there any issues to be aware of when running DVI and USB cables over a distance of, say, 12 or 15 feet from a trunk installed computer to a monitor in the dash?
    Elsewhere
    Run the signal cables down one side of the car and power cables down the other side to minimize the possibility of EMI.
    Some say that high-quality cables are better than cheapie ones. Some use cheapie cables with no problems. Be prepared to try different cables for the best results.
    How about the Wiki?
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    Your monitor will function just fine if you stay at or under 15 ft. For other devices, however, at that kind of length you'll need a powered hub on the other end. The max length of a USB cable is 5m (for full speed devices) or 3m (for low speed devices) - USB devices won't get enough power if you go longer than that without a powered hub on the other end.
    1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    ^^^What they said.
    Mar 2011
    Marietta, Ohio
    Is there a common equation for voltage and current drop over a wire length?
    Elsewhere
    Quote Originally Posted by sall View Post
    There is an equation, yes. V = (25 x I x L) / CM
    This site explains it: http://www.stealth316.com/2-wire-resistance.htm
    It also has a handy calculator for voltage drop.
    How about the Wiki?
    Mar 2011
    Marietta, Ohio
    ^ Thanks!
  1. Mounting Computer in Trunk
    By hopjet24 in forum Fabrication
    Last Post: 08-11-2007, 05:34 PM
  2. Mounting Laptop in Trunk
    By bimmeracer in forum Fabrication
    Last Post: 11-09-2006, 08:47 PM
  3. Help Mounting PC In Trunk S40
    By silv3rman in forum Fabrication
    Last Post: 08-04-2006, 11:19 PM
  4. mounting PC in trunk
    By animul in forum General Hardware Discussion
    Last Post: 09-04-2003, 01:20 AM
  5. Mounting PS in Trunk?!?!?!?
    By solaraboy in forum Power Supplies
    Last Post: 09-23-2001, 01:09 PM
