Results 1 to 6 of 6
Thread: Buttons and input
    May 2005
    Buttons and input
    You know how on ATM machines the hardware buttons along the side of the screen have different functions depending on what screen you're on. The "function" of the button is displayed on the screen next to the button and can change from screen to screen.
    I was thinking of using 4 hardware buttons (preferably small metal capacitive buttons) along the bottom edge of my screen. Are there any Car PC apps that allow for such screen-dependant functionality?
    ie: I'm in my media player - the typical "back, forward, vol up, vol down" buttons on the screen are replaced with "Back, Forward, Vol +, Vol -" markings on the screen above the applicable hardware button. Touching one of the buttons would perform the indicated function.
    On another screen such as navigation, the buttons could be mapped to different functions, such as "Destination, Menu, Zoom in, Zoom out".. etc...
    Jan 2008
    not any premade options i'm aware of, though a quick-n-simple ladder tree resistor circuit with a carpc joycon would be the easiest method.
    Newbie theBlueLight's Avatar
    Aug 2008
    Melbourne, Australia
    Sounds like something that one of those fancy Logitech keyboards with assignable macro keys can do. When you switch applications, the same keys perform different tasks. Maybe you might be able to get hold of a second-hand gaming mouse by Logitech or Razor or something and use it as a controller, connect the buttons to it and use the profiler to assign keystrokes or commands for the various applications you are using? The profiling software will detect when you have switched applications and will reassign the commands for you.
    May 2005
    Good idea, but I don't want different commands in different applications, I want different commands in the same application, but based on displayed page. (ie, one set of functions for the media player in RR, another set of functions for when iG is running, another set of functions for the RR home screen, etc...)
    Aug 2008
    Isn't RR just a front end? If you profile for the applications that are running underneath it, eg Winamp if your using that for the media player and iGuidance then I imagine it would still work, but I could not be sure if the profiler would work considering the applications are technically running at the same time, unless it is clever enough to detect which app is selected at the time.
    Jan 2008
    ^ i believe that method would involve some more-then-average coding, where you need to detect what screen the FE is displaying, and have a certain code set for each screen..
  1. Replies: 0
    Last Post: 10-13-2009, 05:28 AM
  2. Help! Lilliput changed input, I am missing buttons
    By Snootch in forum LCD/Display
    Last Post: 10-11-2009, 10:37 PM
  3. Assigning analog input to keyboard buttons?
    By smellygas in forum Fusion Brain
    Last Post: 06-04-2008, 01:08 PM
  4. How to integrate factory steering wheel input buttons?
    By greatwhite in forum Input Devices
    Last Post: 01-15-2008, 07:12 AM
  5. serial input buttons
    By Ralphh85 in forum Hardware Development
    Last Post: 03-12-2007, 02:47 AM
