Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
Thread: Help with 12V to 5V step down converter.
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    I bought a 150 watt, 30amp, step down converter. Its supposed to take me from 12V to 5V. i am using this for all my hubs and many 5V based devices. My understanding is that this unit steps down the voltage by turning the extra energy into heat.
    Obviously I have to cool this thing down, so would it be ok to build an enclosure to cool the unit down? Basically it would have a fan to the right and left of it, so the air passes through the fins to cool it. Im just worried that cooling it to much will kill its function. If I cool it to much will that mess up its ability to stepdown to 5V?
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    You can't over cool it with fans. Overcool would be putting it in a freezer, and then the problem would be condensation/moisture as it warmed.
    Palm sized ainol MiniPC, 8" Transreflective PRO, Win10, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE.
    Dec 2007
    Sydney Australia
    The only energy the device would dissipate would depend on the current it is sourcing.
    Many electronic converters just chop the 12V and then smooth it again to give the 5V required so there is little heat generated as you expect when dropping 7V@30A across a drop-down resistor.
    I would connect it up to your load first in an open position and feel how much heat it generates by feeling the heatsink.
    Are there any specs which show the Watts dissipated ?
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
    Jul 2007
    Miami
    Thanx, that all makes sence. Here are the stats listed on the website.
    Input Rage: 10 - 30 VDC
    Output: 5 VDC
    Output Current: 30A
    Waterproof;
    Light compact, convenient to use and transport;
    Switching mode power supply, Non-isolated, efficiency:> 90%;
    Ambient temperature at -10 ℃ ~ 45 ℃;
    with overload / over-current / over / low voltage protection (some of the products have the protection of plus or minus reverse), stable performance.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
    Dec 2007
    Sydney Australia
    OK so 150W @ >90% efficiency means about 167W total at full-load from the 12V supply.
    This means that at full-load the converter will only need to dissipate about 16W and less if not at full-load of 30A @ 5V.
    Chances are with that large metal surface area heatsink it will only get warm to touch with normal convection cooling but give it a run to check before you stash it anywhere.
    Jul 2007
    Miami
    All the devices will be pulling about 21 amps. So I should be good? I could just have the fans in case. This will be tucked in a tight space.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    You should have no heat issues with a switch-mode supply at that current, case fan air should be ample and as suggested, run it loaded for about 20 minutes and verify it holds at a stable temp in its installed location.
    Jan 2008
    i would probably put a fan right next to it, so some directed airflow is going across it, but other then that, the case options are up to you.. i might need to pick one of those up for my 5v hub..
    Raw Wave
    Nov 2009
    It should only dissipate ~16W - hence less than a 21W bulb. And in that finned-case, that should not be a problem.
    It may have thermal limiting anyhow, but feeling it as comfortably warm should allay any fears.
    If it were linear, then it would dissipate up to 300W, but it isn't - its an SMPS.
    BTW - how $much & where from?
    FLAC Mickz's Avatar
    Sep 2009
    Australia
  1. DC-DC Step Up Converter
    By sall in forum How to Power a Laptop
    Last Post: 06-13-2012, 10:10 PM
  2. Replies: 12
    Last Post: 07-24-2006, 06:35 PM
  3. step 1 bondo, step 2 ? ,step 3 profit
    By microbionic in forum Fabrication
    Last Post: 08-30-2004, 08:49 PM
