Results 1 to 10 of 20
Thread: Stop Beep at Startup
    Mar 2011
    Marietta, Ohio
    When booting my computer it always makes a beep sound right as the bios is loading. I disasbled the internal speaker through windows but has no effect. How can I disable this beeping at boot? Is there a jumper somewhere on the motherboard?My PC is exactly like this one.
    Thanks!
    Jan 2008
    why not enable the internal speaker, and either physically remove it, or put a piece of tape over it?
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    Some motherboards just don't have a setting to turn off the beep at boot. If there's not a setting in the BIOS/UEFI, then there's nothing you can do about it, unfortunately.
    Oh, and your link doesn't appear to work - it just takes me to the main ebay page. Posting a link to the actual manufacturer and model specific page would be better.
    1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
    Mar 2011
    Marietta, Ohio
    Yeah, it's the correct link something with mp3car doesn't let it go through... don't like eBay I guess. Manufacturer page:
    http://www.migrus.com/index.php?main...roducts_id=263
    Nov 2010
    Panama City Beach
    You should contact the manufacturer to see if it's possible.
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    Random thought:
    It’s usually a small piezo sounder/speaker on the MB, some are just plugged in, unplug or put a bit of tape over the front of it and reduce output by up to 80%.
    Palm sized ainol MiniPC, 8" Transreflective PRO, Win10, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE.
    Mar 2011
    Marietta, Ohio
    I don't think the speaker itself can be removed. Looking through BIOS I didn't see much that stuck out to me. I'll contact Migrus and see if they can shed any light on the issue. Other than that I'll try the tape suggestion. Just one of those annoying little aspects of the build.
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    It’s a tiny round black thing with a hole in the middle; usually around ” dia. If it unplugs it will be attached to a lead.
    These days most are permanently mounted on the MB. Cover the hole if you find it.
    Mar 2011
    Marietta, Ohio
    It's definitely soldered to the motherboard. Just contacted Migrus will see how quickly they respond!
    Low Bitrate Zephrant's Avatar
    Sep 2010
    I used a drill bit on the one in my car- Just destroy the little piece of metal in it and it'll be quiet for ever. Of course that's a rather violent (and satisfying) way to deal with a beep that won't stop...
    Zotac H55-ITX w/ 802.11n WiFi, i3-550/3.20GHz, 8GB DDR3 1333MHz, 120G Intel SSD, P2140,
    7" pseudo-transflective resistive TS, Win7-64, Centrafuse 4.3, Elmscan Compact 6, BU-353, Rear camera, Trailer camera
  1. Replies: 1
    Last Post: 11-14-2009, 10:21 PM
  2. Hear the startup beep, stalls at tests screen sometimes
    By yukon in forum General Hardware Discussion
    Last Post: 06-04-2007, 08:34 PM
  3. Beep Beep!!!,RR, CSX, Iguidance help please
    By prussia in forum Road Runner
    Last Post: 09-06-2006, 12:02 AM
  4. How to stop PC beep when return from standyby??
    By Deff in forum General MP3Car Discussion
    Last Post: 03-13-2006, 09:21 AM
  5. EPIA startup BEEP
    By slboytoy in forum General Hardware Discussion
    Last Post: 10-26-2003, 03:19 PM
