My Zotac has the 24 pin connectors. The PC works perfectly without the 4 pins connected.
Currently I have a 20 pin pico PSU wide band DC-DC 120w power supply for my motopc. I have that in a D510MO motherboard. I am looking at the intel D525 board for various reasons and noticed that it has a 24 pin atx connector just like the D510 but it also has that 4 pin CPU power connector. I was wondering if there is a solution to make that PSU work with that mobo?
HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
4x 10inch Tablet
1x Win 7 / Rear Entertainment PC
ft/ Web Server Streaming
Like HiJack said, you don't need anything but the standard 20 pin connector to power your motherboard.
1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
If your talking about the 4-pin atx 12v connector and not the extra 4-pin plug on the 24-pin EATX PWR plug. You will need that(4-pin ATX12v) plug so the motherboard will boot. That plug supplies power directly to the CPU and will not work without it. You can get away without connecting the extra 4-pin plug on the EATX so you just have the 20-pin plug connected. But you will need a 4-pin(2x 12v+ and 2x 12v-)plug for the CPU. You should be able to buy an adaptor to fix this or make one yourself. With the 24-pin EATX PWR plug, The extra 4-pin is for extra pwr for the CPU if it needs it. But in most cases especialy with carpc's your pc wont need the extra power.
um, your using the pico psu in a motorcyle/automotive environment?
My 2001 Mitsubishi Eclipse GT:
"The Project That Never Ends"
more projects then time!
Led Skyline Tail Lights--100%
High Power Led Reverse Lights--100%
Led third brake light--100%
Led front turn signals--0%
HID retro--100%
Be aware, that the picopsu wide input requires 12-15V input That means if you hook it directly to an automotive electrical system you will burn it, and/or anything attached to it up. Be sure you are hooking it to a regulated 12V source, not raw automotive power (Which is 8-16 or so volts, depending on other factors)
http://www.e-itx.com/m3-atx.html
This is the PSU.
I found a solution that converts a regular 4 pin molex connector to the P4 CPU power connector
So as far as the PSU, it takes 6-24 volts DC in. and it is installed into a sport bike. I will be throwing up a V2.0 install when I get all the new parts in.
