Results 11 to 20 of 29
Thread: Help with 12V to 5V setup, having powering issues.
  1. #11
    Jan 2008
    you'll need a transistor-- look around the M2 section. there are a couple of threads that talk about a solution to the low output of the anti-thump pin(where it won't have enough juice to turn on some amps)-- that circuit should be the exact thing you'll need.
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
  2. #12
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Well the PAC has enough juice to turn on the relay, the problem is that its a pulse device so its turning off the relay off and on really fast. I figured that if I put a capacitor, then it would store the pulse and release it as constant, or do I have things wrong?
    HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
    4x 10inch Tablet
    1x Win 7 / Rear Entertainment PC
    ft/ Web Server Streaming
  3. #13
    Jan 2008
    ah...
    i was going to start on the explanation of how to make it work, but honestly, it is much more work then it is worth. you'd need a diode to prevent the voltage from going back into the PAC, a resistor to keep the voltage going slowly through the relay, a capacitor to store the charge, and a least a weekend to figure out what values of resistor and capacitor are the correct ones for this application...
    just get one of the devices i linked to before-- that will solve the problem and give you a larger adjustment window if the 2 seconds isn't enough..
    HID retro--100%
  4. #14
    Raw Wave
    Nov 2009
    Thru a diode to a cap to the PAC....
    Don'tcha hate products without specs (TR4) like input current & impedance, time delays etc.
    (Hence why so many DIY with web circuits.)
  5. #15
    Jul 2007
    Miami
    Quote Originally Posted by OldSpark View Post
    A diode to a cap to the PAC, or did you mean the relay?
    Well I know the time delay is 2 seconds on the PAC.
    4x 10inch Tablet
  6. #16
    Jul 2007
    Miami
    Is this what I am doing?
    4x 10inch Tablet
  7. #17
    Jan 2008
    yes, it would need to be on the output side of the PAC.
    though, oldspark will need to confirm, i thought that a resistor would be needed in something like this to prevent a smaller-sized capacitor from discharging too fast between pulses..
    HID retro--100%
  8. #18
    Jul 2007
    Miami
    What is the purpose of the diode though? To keep the current from going backwards?
    4x 10inch Tablet
  9. #19
    Raw Wave
    Nov 2009
    Quote Originally Posted by some stupid OldFart
    Sorry - my bad - I meant "Thru a diode to a cap to the device...." (ie, relay).
    The point being the diode.
    As per HiJack's diagram, from PAC TR4 thru diode to cap & relay.
    The PAC charges the cap (hopefully without stressing the PAC's output).
    When charged enough, the relay turns on (ie, when voltage across the cap exceeds the relay "turn on" voltage.
    When the PAC turns off, the diode prevents the cap discharging thru the PAC. It must discharge thru the relay coil etc.
    The 10k fixed resistor is not needed - it is only there to discharge the cap.
    But the (say) 60R to 250R (R=Ohm) coil resistance "swamps" the 10k (eg, parallel R = (10k x 250)/(10k+250) = 243R = close to the 250R)
    - ie, the cap discharges through the lowest resistance (250) much quicker than the 10,000 resistor.
    If only audio buffs could fit a diode between their supply (battery, alternator) and the cap and amplifier.... (LOL!)
  10. #20
    Jul 2007
    Miami
    Thanx for clearing that up OldSPark. I actually understand this time too! LOL
    4x 10inch Tablet
  1. New Setup and P2140 is not powering PC
    By brianteel in forum Power Supplies
    Last Post: 12-13-2009, 03:04 PM
  2. M2-ATX Powering Issues
    By kraimer21 in forum Power Supplies
    Last Post: 06-01-2009, 06:50 AM
  3. Replies: 7
    Last Post: 03-18-2008, 08:25 PM
  4. Powering XM Direct for Laptop Setup?
    By tiomka in forum Car Audio
    Last Post: 05-31-2006, 10:36 PM
