Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Help with 12V to 5V setup, having powering issues.
  1. #21
    Maximum Bitrate Mickz's Avatar
    Sep 2009
    Australia
    Just a couple of thoughts, The TR7 has pulsed outputs but I haven’t seen that indicated for the TR4.
    I would switch +12v input to 12v to 5v unit instead of +5 output. Less current demand on the relay but if you only drawing low current then I guess it doesn’t matter.
    I carried out some tests with powering +5v to the HUBs before the PC had powered up. Got strange results with various USB devices not initialising at start-up. The MS web cam shows up as an unknown device on the bus. Results were consistent every time and this was with a Linear +5v regulator.
    I have one of those inverters you use here, mine is a 100 watt unit. Had quick test and it appears to start up fine with no delay, however as the spec said, 12v- 24v input but will run 10v to 24v. There is a definite on/off pulse and low voltage with anything below around 10.1 volts. I would imagine that if over 10v was not immediately available at start-up then it may give some strange results. It’s also not a clean cut-out of +5v output if the input voltage dips to around 10v.
    Have you tried something simple like a large cap across the output of the inverter? I think your unit is rated at 20A so there should not be a problem with inrush current with a largish cap.
    Just some random thoughts, on the way out so I may have misunderstood something with my quick read of your problem, apology if so.
    GA-Z77N-WIFI, i5-2400S, 8GB, Intel 520 128GB SSD, M4-ATX Modified, 2 Rev Cams, 2 Web Cams
    8" 16:9 TRANSFLECTIVE, Win8-64, Dual GPS RX and Garmin PC + Odyssey Nav, FM-DAB+, BB-Rec
    T-Screen HVAC control, custom microcontrollers, code and FE. CarPC Project
  2. #22
    Raw Wave
    Nov 2009
    Gi'dam...
    Things like....
    Quote Originally Posted by Mickz View Post
    scare me.
    I think inverter... dc to ac... no cap across ac (well, not to filter below 50/60Hz etc).
    Flashback - capacitors on PWM outputs...
    Not that I recall a inverter in this thread. I thought it involved converters - ie, dc-dc.
    Ah, jargon fun.
    dc-dc converters involve inversion or inverters but are called converters, not inverters - at least in my general experience.
    Inverters are dc-ac. But aircons and welders now have "inverters".
    And UPS were thought of as ac-dc-ac but can include ac-dc (and dc-dc).
    Yes, it pays to know the audience and THEIR jargon.
    At least ships still carry CARgo and cars carry SHIPments.
    As to relays NOT isolating batteries....
  3. #23
    Sep 2009
    Australia
    Yes, that’s just me spewing something out quickly, like I said, in a hurry at the time.
    It’s a 20A DC to DC Step down Convertor and a cap may help ease any weird voltage fluctuation that may be happening at start up or at least identify if there is a problem there.
    This device is short circuit proof.
  4. #24
    Sep 2009
    Australia
    Strange forum happenings here, double posts and no response most of the time. Tried to delete this second post that apeared.
  5. #25
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Yea, they are trying to add a new feature to the forums and its causing chaos.
    HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
    4x 10inch Tablet
    1x Win 7 / Rear Entertainment PC
    ft/ Web Server Streaming
  6. #26
    Jul 2007
    Miami
    What are OldSpark and Mickz talking about? You guys lost me. Im going to head to Radioshack and see if I can find a capacitor and diode.
    4x 10inch Tablet
  7. #27
    Jul 2007
    Miami
    OK, I had a hunch.... I was using 2 different PSUs to power each item. Once I combined the connection to one, it all worked perfectly.
    4x 10inch Tablet
  8. #28
    Raw Wave
    Nov 2009
    You have connected 2 supplies together (ie, their outputs)?
    That is usually risky, but sufficient output resistance else appropriate design can save the day.
    (Speaking of which I recently read threads where they increased the output voltage of one ATX rail by increasing the load on the other. IE - bad design - a shared ground path. I prefer to add diodes or change the feedback resistance!)
    Now let's see if this double-posts....
  9. #29
    Jul 2007
    Miami
    OldSpark.... not together. One PSU was powering the 12V to 5V converter and the relay. The other was only powering the PAC TR4.
    4x 10inch Tablet
  1. New Setup and P2140 is not powering PC
    By brianteel in forum Power Supplies
    Last Post: 12-13-2009, 03:04 PM
  2. M2-ATX Powering Issues
    By kraimer21 in forum Power Supplies
    Last Post: 06-01-2009, 06:50 AM
  3. Replies: 7
    Last Post: 03-18-2008, 08:25 PM
  4. Powering XM Direct for Laptop Setup?
    By tiomka in forum Car Audio
    Last Post: 05-31-2006, 10:36 PM
