Results 1 to 9 of 9
Thread: License plate receiver
    Dec 2007
    NY
    Is there a gps receiver out there, preferably bluetooth, that can be mounted on the license plate? Sort of like an ezpass?
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    Well, you could probably mount the GPS receiver wherever you wanted, you'd just have to fabricate something. But, that's not exactly the best place for one, since it wouldn't be in direct line-of-sight to the sky quite a bit of the time. Any particular reason you need to mount it on the license plate?
    1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
    Dec 2007
    NY
    I just don't want it on the dash or on the roof.
    Nov 2010
    Panama City Beach
    If you want a good GPS signal, then it needs to go somewhere where it can see the sky. If you wouldn't mount an XM antenna there, you wouldn't mount a GPS receiver there, either.
    Jan 2008
    sometimes you can mount the gps antenna under the plastic dash and it will still get a good signal. though it is something that you need to play with-- some cars just don't work with this technique.
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    I have put receiver's in taillights, clearance lights, under plastic dashboards, under plastic/composite hoods or rear decks. When inside make sure no defroster wires in rear window or front in glass antennas. GPS receives the best signal when its on top of a 36" flat metal surface (ground plane) thats optimum and away from other antenna's by at least 12-18". Just can't go through metal and most satellites are south facing so keep that in mind when positioning receiver i.e. slope of windshield vs roofline, if tailight is sloped enough to allow good sightling to the sky, if you look at most rental cars they are all on the outside of the top front fenders closer to the headlamps than the windshield. I install tracking units for a living and most clients want covert installs so its really on a vehicle to vehicle basis, same vehicle same year just different options make for diffierent install locations. Hope this helps SNO
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    ^^^ great advice.
    I would look inside the dash, close or under a speaker grille, air vent, or something "thin" like that.
    FLAC hexxamillion's Avatar
    Dec 2007
    AZ
    That was some good tips.
    Sent from my DROID BIONIC using Tapatalk
    "Live Free!!!...It's all about Open Source"
    Recent Proj
    Old Proj II
    Old Proj I
    YouTube:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
    Dec 2007
    NY
    I think under the dash sounds good, I think the cars GPS is there, and there is a speaker there....funny, I was reconsidering my plan and on my way to just putting it in the back window since it was going to be tinted until I read #6, thanks.
  1. License plate camera?
    By hari-bhari in forum General Hardware Discussion
    Last Post: 01-21-2007, 12:13 AM
  2. My new license plate (pic)
    By aoLhaTer in forum General MP3Car Discussion
    Last Post: 05-12-2005, 11:34 PM
  3. LED license plate
    By Custommx3 in forum General Hardware Discussion
    Last Post: 05-27-2004, 06:36 PM
  4. License plate frame
    By Dr Jeckyl in forum General MP3Car Discussion
    Last Post: 04-17-2004, 02:33 AM
  5. Cool License Plate
    By CaffeineAddict in forum Off Topic
    Last Post: 07-26-2002, 01:00 PM
