Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 57
Thread: Serial PC Interface for HD Radio (Directed) - DIY??
  1. #21
    Variable Bitrate we87's Avatar
    Nov 2005
    Dallas, TX
    Quote Originally Posted by malcom2073 View Post
    ....If you remove the transistor and just wire pin2 of the DIN to 5V through the 1k resistor, it should be always on for testing.
    Tried this today, and it still doesnt work.
    The serial cable I am using is a high quality Belkin cable thats shielded and everything, and its only about 4 feet long, PLUS I test the continuity of the pins so I know its not broken at all.... I did the same thing for the DIN cable I have, it came from my XM radio box when I got it.... So now I am completely stumped. I know the serial port is on because I get voltage on just the DTR pins and Ground when I checked with a voltmeter..... I honestly dont know what else to try.
    EDIT: I got another serial cable, and made it shorter thinking that possibly the longer wire caused a voltage drop. That didnt change anything. I tried a different PC, and that didnt change anything. When I rebuilt everything to the schematic specs (and I added a diode on DIN2) I can hear the HD box clicking on when the app is run, so I know 100% the app is turning on the HD box, then when it stops searching and fails I hear another click when would be HD power box turning off. Is it possible the wires listed on that site is wrong? Perhaps the transmit and receive is backwards? Has anyone actually built this cable and got it to work? I know "phuz" said he built the cable, but never actually said it was fully functional with RoadRunner...
    Carputer Progress
    [||||||||||] 100%
    Finally Installed!!
    Everything is in the car and working.
    I painted the cilpboard mount and it looks good.
    Shutdown/Startup is working excellent!
    View My Progress Here
  2. #22
    Jul 2011
    was wondering if anybody has got this to work. i built the cable and and i used a rs232 to usb converter. i downloaded the hd radio software hdradiopcr from mitchjs website. when i turn on my laptop, i hear the box click to turn on and then it will click a few more time. roadrunner will not recoginze it at all. i am at the point where i am about to break down and just by the usb cable to just be done with it, i just dont want to spent the $40 just yet.
  3. #23
    Jul 2011
    thanks, i will try building this circuit tonight. for the port settings is that something you do through the bios or through rr?
  4. #24
    MySQL Error
    Oct 2004
    i am the manufacture... please delete the image
    it already got stolen once.... without permission
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  5. #25
    Mod - Driveline forum
    ClockWorK's Avatar
    Oct 2003
    Michigan
    Is the image copyrighted? Like, someone would just need to create their own version of this schematic and then upload that instead?
  6. #26
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    Sorry, I did not know it was copyright, It had no markings but was obviously not made by Directed so I had to draw up what I measured with a meter in order to figure out how to connect to my motherboard.
    Robert
    Sent from my SCH-I535 using Tapatalk 2
  7. #27
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    Mod, please delete my image link as courtesy to Mitch, as I am out of town in a training class and cannot edit posts from tapatalk.
    Again Mitch, sorry to reverse engineer your part.
  8. #28
    Jul 2011
    does anybody know what happen to the diagram that was posted here from yesterday?
  9. #29
    ClockWorK's Avatar
    Oct 2003
    Michigan
    Check your web browser cache (Temporary Internet Files).
  10. #30
    Jul 2011
    I guess I am doing something wrong because when I go to my cashe it just reloads this page
  1. Directed DMHD-1000 HD Radio Serial Connection Pinout!
    By srlake in forum General Hardware Discussion
    Last Post: 03-25-2012, 12:25 AM
  2. Directed HD Radio Causing static in factory radio
    By bchiang in forum Input Devices
    Last Post: 09-28-2011, 07:10 PM
  3. FS: Directed HD Radio + MJS Serial Cable $30
    By billmee in forum Classifieds
    Last Post: 06-08-2011, 06:09 AM
  4. Replies: 14
    Last Post: 10-11-2010, 03:44 PM
