Page 1 of 6 123456 LastLast
Results 1 to 10 of 57
Thread: Serial PC Interface for HD Radio (Directed) - DIY??
    Dec 2007
    Mohnton, PA
    I notice that there is a separate USB cable for the Directed HD Radio interface, but I failed to notice this when I made my purchase. I see that it creates a virtual COM port, but since I have several spare serial ports available on my CarPC, can I just fabricate a serial-->hd radio interface cable myself?
    I have plenty of spare cables with both necessary plugs. I would just need to know the pinout I suppose.
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    This link has info on making the serial cable for the hd radio http://www2.dasilvas.info/hd-radio hope this helps SNO
    Dec 2007
    Mohnton, PA
    Thanks.
    I used that link, and built the circuit as shown. I chose the HD Radio (Directed) - COM7 option in RR config. I made sure my COM7 settings were 115200, 8, none, 1. RR launches the radio player as if it sees the radio, then after a few seconds it says it cannot find the radio and to check COM settings.
    It is definitely getting powered up, but not sure what else I'm missing.
    Dec 2007
    Mohnton, PA
    Turns out that it helps to NOT confuse pin 1 with pin 5 when wiring up the RS232 port
    Variable Bitrate we87's Avatar
    Nov 2005
    Dallas, TX
    So if I follow this cable schematic, and make a serial cable for the HD radio module, will it work with Centrafuse? As in would I be able to control it right from the front end?
    Carputer Progress
    [||||||||||] 100%
    Finally Installed!!
    Everything is in the car and working.
    I painted the cilpboard mount and it looks good.
    Shutdown/Startup is working excellent!
    View My Progress Here
    Nov 2009
    Keswick,On Canada
    Yes it will, It will work in most front-ends CF, RR, Streetdeck and sometime soon to Driveline SNO
    Oct 2006
    thanks for the link. going to order the tuner and build a rs232 cable now. i'm out of usb but have a com port open to use.
    SNOtwistR - How does the HD Radio (directed) work in canada for you? any issues?
    95 Mustang 5.0
    Custom Case, VIA m10000, 512 MB, 80gig, M2-ATX, Slot Load DVD, 7" LCD Touchscreen
    80% done
    Nov 2009
    Keswick,On Canada
    No issues at all just no HD. I bought for the AM option also but FM sounds really good and works in most front-ends
    Nov 2005
    Dallas, TX
    It should pick up radio just like a real head unit, correct? Considering it is the same exact unit that you would USE with a real head unit? At least thats what I would think... I cant wait to build the cable
    Carputer Progress
    [||||||||||] 100%
    Finally Installed!!
    Oct 2006
    i have read that people were having problems with it switching back and forth from HD to non-HD because it was losing its signal. if theres no HD available, this wont be a problem and it will just use AM/FM.
    95 Mustang 5.0
    80% done
  1. Directed DMHD-1000 HD Radio Serial Connection Pinout!
    By srlake in forum General Hardware Discussion
    Last Post: 03-25-2012, 12:25 AM
  2. Directed HD Radio Causing static in factory radio
    By bchiang in forum Input Devices
    Last Post: 09-28-2011, 07:10 PM
  3. FS: Directed HD Radio + MJS Serial Cable $30
    By billmee in forum Classifieds
    Last Post: 06-08-2011, 06:09 AM
  4. Replies: 14
    Last Post: 10-11-2010, 03:44 PM
