Results 1 to 4 of 4
Thread: Advice on Hardware Selection
    Dec 2011
    Hello all, it's been a while since my last carputer (~2003). I even forgot my user name and password. I recently picked up a project car and would like to get back into the whole carputer scene. My main uses for now will be music videos, and GPS. If you feel there are better selections, feel free to post your suggestions or solutions.
    Software:
    Centrafuse
    Monitor:
    -Lilliput 669GL-70NP/C/T-HB-RV
    -Double din kit
    Audio:
    -Pioneer single din
    Case:
    -Morex 5677
    Motherboard:
    -Asus Atom D525
    http://www.newegg.com/Product/Produc...82E16813131731
    OR
    -Asus E-350
    http://www.newegg.com/Product/Produc...82E16813131732
    Power Supply:
    -M2-ATX 160
    OR
    -M4??
    Bluetooth:
    -Any generic?
    Wifi:
    -Recommendations?
    GPS:
    BU-353
    Jan 2008
    the m2 should be plenty for that board, and your current devices.
    also, be sure to check cf's required parts page-- i believe any BT module will work, but i'm a rr user
    otherwise, looks like a good plan.
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Dec 2011
    Thanks for the advice in regards to the power supply.
    Which board/CPU is generally preferred here in the carputer world? The atom d525 or the e-350?
    Jan 2008
    that seems to be better decided by how you feel towards 'intel vs. amd'.. overall, i don't think there is much of a difference between the two. both are low powered chipsets, both come in passively-cooled options, so noisy fans aren't there, and both have about the same amount of processing power..
    the atom has been around longer, so i think it has developed a little more of a following, and as such is a little more popular, but i really don't see a significant advantage either way..
    HID retro--100%
  1. Aust350z: Hardware Selection Help
    By Aust350z in forum General Hardware Discussion
    Last Post: 02-14-2011, 07:06 PM
  2. Need a little hardware advice.
    By kameleon in forum General Hardware Discussion
    Last Post: 02-01-2007, 06:23 PM
  3. OBD-II Hardware Inteface and Cable Selection
    By hoffmandirt in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-08-2006, 04:58 PM
  4. Replies: 1
    Last Post: 06-16-2006, 08:09 PM
  5. Line Driver Selection? And Audio advice
    By Philly#1 Lex in forum Car Audio
    Last Post: 04-24-2006, 11:10 AM
