Results 1 to 4 of 4
Thread: Two switches into the 2 pin mobo on/off?
    FLAC -zip-'s Avatar
    Ontario/Canada
    Hi guys,
    Tweaking one of the carputers over the winter. It has an opus 250 power supply. The power supply has a two wire lead to connect to the mobo to turn the PC on and off. I would like to tap into that wire and run a second momentary switch. Tried using a relay, was not very good and want to use a different method.
    Is this possible? or any suggestions other than a relay would be appreciated.
    Sound Stage
    Eclipse|MTX|Infinity
    Jan 2008
    completely possible-- my setup has a remote mounted power and reset button..
    just use a N.O. or Normally Open momentary push button. just connect it to those 2 wires(i soldered a spare 2 conductor cable onto the dc-dc's power button wires), and it should work just like you need it to.
    FLAC -zip-'s Avatar
    Ontario/Canada
    Thanks soundman, glad you are around to answer everyones questions.
    Sound Stage
    Jan 2008
    just be sure to return the favor occasionally
  1. Replies: 5
    Last Post: 04-09-2010, 12:57 PM
  2. switches??
    By pumm3l in forum General Hardware Discussion
    Last Post: 06-29-2007, 02:29 PM
  3. Switches?
    By MikeyTampa in forum Newbie
    Last Post: 04-22-2005, 08:23 PM
  4. WTTF Nice momentary switches/Rocker switches
    By CavityCr33p in forum Classified Archive
    Last Post: 04-14-2005, 01:44 AM
  5. Switches for a car
    By leenas in forum General Hardware Discussion
    Last Post: 06-23-2003, 11:36 PM
