well one thing is that you probably have it hooked up to accessory power which does drop out as the car is cranked, just like the radio does. one easy fix may be to power it from ignition rather than accessory. ign will not drop out on crank. the drawback then would be that the tablet will not be powered in the accessory position which is reached by just tapping the start button without your foot on the brake and not really starting the car. if you want it to be on accessory power but not loose power on crank you could power it with both ign & accessory by way of a relay or a few diodes... do NOT run both ign & accessory power to the tablet without a relay or diodes as this will cause all of the other accessories to be back fed from the ign feed.
I think either one of these options would be better than a timer. a cap might work too but I'd question how reliable it would be throughout the temperature extremes and possibly long cranks or restarts... feeding it ign or ign & accessory isolated from each other is probably your best bet & not so hard to do really...
LinkBack URL
About LinkBacks
