Results 1 to 7 of 7
Thread: What type relay are these?
    Newbie jfxwave's Avatar
    May 2006
    Corpus Christi, Texas, United States
    I have 4 linear actuators and they came with a diagram and i don't know what type of relay they are.
    I have lots of the normal relays so if anyone can help using these relay in place of the above i would be very thankful.
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    Looks to me like the relays are basically just switching pos and neg at the same time. Basically one is functioning in one polarity and the other is reversing the polarity to move the actuator the other way.
    Just use two normal relays in place of each of the shown. Have one go to power and the other go to ground. Do the same thing with the other relay, just opposite.
    Sorry I can't sit here and draw out a diagram for it right now, but if you don't get my drift reply to this and if i don't get to it in a while shoot me a PM to remind me and I'll try to get to it as soon as I can.
    ibf
    ibf is online now
    Oct 2010
    Its double pole double throw.
    Its basically 2 switches in the same package, the switches are controlled by the single coil at the same time. Like above you can use 2 normal car relays by connecting the 2 coils together.
    Here is your usual car relay >
    May 2006
    OK i still don't understand what wire goes where on the normal car relay. I should have posted the other picture that shows the limit switches.
    Oct 2007
    Haledon, NJ
    First thing you need to make sure the relays you have have 5 pins on them... many only have 4. In order for them to work properly in this situation you much have 5 pin relays.
    I don't have time tonight to make a diagram.
    Pin 85 - coil +
    Pin 86 - coil -
    Pin 30 - power or ground source (depending on what you need to switch
    Pin 87a -connected to pin 30 when the coil is not charged
    Pin 87 - connected to pin 30 when coil is charged
    Oct 2007
    Haledon, NJ
    May 2006
    Thanks i got it working.
  1. e46, Rear-View, Relay... suggestions to relay...
    By house98 in forum General Hardware Discussion
    Last Post: 11-25-2009, 06:06 PM
  2. What type of sensor constitutes what type of input?
    By Crawdaddy in forum FB Sensors
    Last Post: 11-22-2007, 10:04 PM
  3. PCMCIA Extension - Type 3 to Type 2
    By ukchris in forum General Hardware Discussion
    Last Post: 10-01-2005, 12:13 AM
  4. Replies: 1
    Last Post: 06-10-2005, 04:09 AM
  5. Problem with connecting 2 Type II pcmcia cards to a Type III slot.
    By AVmobile in forum General Hardware Discussion
    Last Post: 01-28-2004, 10:14 PM
