Results 1 to 3 of 3
Thread: Reducing core temp
    Dec 2007
    NY
    Reducing core temp
    My processor is running at 54C idle in my home well ventalated....with a house fan pointed straight through the vent (it is the same temp without the fan as well)
    GPU@54C
    HDD@35C
    MOB@38C
    I came across something in another forum where this guy found a tool to reduce the temp of the core considerably, but when I went to find this software it was no longer available, this is what he said:
    By using RMClock, I was able to:
    1) Reduce the AMD Neo X2 CPU multiplier from 7.5 to 4 resulting a CPU running @ 800MHz when in idle mode (most of the time on an HTPC)
    2) Reduce the temps from 72 C to 49C resulting less fan noise
    3) "On Demand" power-up (from 800MHz to nominal 1500MHz by steps) when playing games, music, surfing,...
    Does anyone know of any other reliable and reputable software that can accomplish this? I can only imagine when I get this in the car the temp is going to go up by about 10C.
    Thanks.
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    you can download the file from here http://twintower.homeip.net/rmclock.rar SNO
    Jun 2007
    Boston MA
    Have you looked up normal operating temperatures for the CPU/GPU/Chipset? It's entirely possible that 55C is a perfectly normal operating temperature. While some processors throttle when they get hotter than 60C, others don't care. It being a mobile chipset, I suspect that it can withstand a lot more heat (though it should also produce less heat, for the same exact reason)
  1. Core Temp and SpeedFan displaying different temp figures?
    By mos33y in forum Software & Software Development
    Last Post: 04-28-2011, 05:06 AM
  2. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  3. reducing noise, shielding EMI
    By hateeecs in forum Car Audio
    Last Post: 09-08-2005, 10:30 PM
  4. Reducing my boot time bit by bit.
    By themurph1018 in forum General Hardware Discussion
    Last Post: 11-16-2004, 06:39 AM
  5. Reducing Preload Times?
    By M^ck^y in forum MediaCar
    Last Post: 08-30-2004, 05:54 AM
