Results 1 to 10 of 17
Thread: Remote start car from pc
    Dec 2007
    NY
    Has anyone done this? I figure if the pc is running off a second battery or ups this should be possible. This way if your of has wifi communication you should be able to start your car from anywhere wihout paying that monthly fee to viper.
    Jan 2012
    WI
    The best way to do this is with an actual remote start system. They usually have an external trigger wire you could hook up to a pc. Then just have the computer trigger the remote start.
    Sent from my Evo 3D using Tapatalk.
    Elsewhere
    The problem is having a PC running all the time, which will drain your battery....
    How about the Wiki?
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Out of curiosity, what scenarios would require starting your vehicle from further away then the current technology would reach via the remote?
    For carpooling, from a mile away you would think would be sufficient before you get dropped off at your vehicle, getting off a plane, it should work from the airport before you head for the parking area (unless the parking in offsite). Starting your car back home in the driveway while in Florida for the winter can be done via the low batt feature or timed start interval feature.
    I get the cool factor but unless your just into burning off a 1/4 tank of gas before you arrive at the vehicle to ensure the cabin is 72.5 degrees, I just don't get it. I have had a Viper for about 5 years and love it but have no desire to upgrade to get this feature. Maybe it's just me, I don't know. Now I would like to upgrade to get the rechargable remote, mine is hard on AAA batteries.
    Dec 2007
    NY
    x219c, I see what you mean, I just wish i could bypass the remote start all together. But if that's what I have to do I'll do some research.
    DarquePerert, that's the purpose of a secondary battery or ups.
    PhilG, I fully agree with you about the distance factor. I park maybe 100 yards short of a mile from where I live...nice 10 min walk, perfect amount of time for warm up. I was simply looking at the fact I have this computer in the car, why go pay for a remote start, pay for instalation, and carry around an extra remote (which is actually the main reason). I dont want the extra remote, and if I program the remote starter into my fob remote, I'm limited to maybe 100 ft. So just trying to kill multiple birds with one stone.
    Constant Bitrate BoyRacer0013's Avatar
    Nov 2011
    Chicago - northwest side - where the corn fields start.
    What about wiring up a USB relay that can bypass the starter switch. Isn't that basically what remote start dose, it is just controlled with its own receiver and some basic logic. Although if you are going to have an always-on computer you could just remove the wires from the "start" position of the starter switch and use a USB relay to start the car from the computer all the time (not recommended). The Best way to do this that I can think of would be to wire a USB relay in parallel with the "start" position of the starter switch, so that the relay would bypass, but not disable, the switch. How do you plan to know when to stop cranking the car?
    Note: I think you would also need a relay for the "run" position to turn the ECU on and do anything else the run position would.
    Here is a USB relay board that should be more then what is neccessary
    http://denkovi.com/product.php?ProductID=44
    Enter the LOTUS...
    (more info here)
    Pre-build thread
    Planning: ::::::::::::
    Parts: ::::::::::::
    Build: ::::::::::::
    Test: ::::::::::::
    Install: ::::::::::::
    Oh, yeah, and build the car... ::::::::::::
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Boyracer0013 beat me to it, the other issue is starter control. Most of the current RS have an anti-grind feature to disengage the starter at the appropriate time. Some vehicles have this built in now too, I believe my truck does. It prevents starter damage if someone holds the key too long. If you vehicle has that, then that issue is handled, otherwise, it is a major consideration.
    BTW, you can replace the factory remote with the new one if you buy the RS with alarm combo and connect the door lock wires. You can also do some other cool stuff like turn on heated seats, PC etc. before entering the vehicle.
    I love my PC and agree with configuring it to do as much as possible but in my humble opinion, the remote start/alarm is a pretty important piece that needs to be a quality stand alone item. BTW, by replacing the factory remote, you also gain much greater range to lock/unlock doors and continual feedback to know the status of the vehicle. At night before bed, I regularily look at the screen of the RS just to make sure it's locked. I like the extra range on the door locks at stores because I seldom use a cart to shop, (just a guy thing I guess) so before I load my arms up with stuff, I will unlock the truck right from the checkout so no fumbling at the truck, especially if its raining.
    Man, I sound like a RS salesman, sorry....
    Jun 2010
    Vancouver, Washington, United States
    Viper has the app for iphone to start your car via the app. I think this paradigm should be the way to go if that is what you want in your car. I, for one, cannot go this route without the Viper system because my phone will be the internet access for my car, though I guess one could use wifi for the car in the driveway (of course anyone with dedicated cellular internet in their car wouldn't be concerned with this).
    Now this brings up a question. The Wake-On-LAN feature most computers seem to have. Does this work over wifi? Can you have the pc boot up by sending it a signal over the internet using this method? If so, you have your low power option and still can remotely boot the PC and start the car up. Just theorizing here.
    Dec 2007
    NY
    The only problem with replacing my fob is I have a push to start (Infiniti M), I need my fob to drive. I can replace the remote with my fob if it weren't for range, but not vice versa. My problem is this whole venture is beyond me, I was hoping someone did this already and I could copy them, or someone with more experience it messing with cars and interfacing with the pc was willing to do this with their set up and we could do it together.
    Variable Bitrate mayhembdm666's Avatar
    Mar 2008
    Adelaide, Australia
    One addition to remote starting your vehicle will be for people who are on holidays or away for longer then a week, In this situation they are able to run programs to start the vehicle every so often or do it manually via the internet/sms/phone and allow for things like recharging the battery, checking fuel and so on.
    Of course you would want your software to monitor and remember fuel so the amount of starts would decrease as the fuel gets lower.
    Then the usual of warming the vehicle up in the morning from inside, say while checking emails. You then can have a program started remotely via WiFi that will start the vehicle, when at temp shutdown. This can be extended to windows n so on... I could name 101 reasons why this setup would be used.
    I'll personally be looking at having something like the Arduino running 24/7 and then maybe having that controlling the hibernation/sleep times of the PC or setup the InstantBoot option on my ASRock motherboard.. Having the Arduino detect the car being unlocked and then powering up the PC perhaps?
    2004 Holden WL Caprice Auto GENIII
    Base System = Raspberry Pi
    Everything else is pending for now as switched from a Mini-ITX setup
  1. Remote start your car
    By themlruts in forum General MP3Car Discussion
    Last Post: 07-14-2010, 05:00 PM
  2. Remote Start Fried? Car continously tries to start
    By Phatsacks in forum General Hardware Discussion
    Last Post: 08-17-2008, 06:39 PM
  3. Car Remote Start?
    By Cheekz185 in forum Off Topic
    Last Post: 10-30-2005, 01:39 AM
  4. Remote Start for your PC
    By Norrin302 in forum General Hardware Discussion
    Last Post: 08-24-2005, 11:29 AM
  5. Remote Start
    By kane2g in forum General Hardware Discussion
    Last Post: 04-25-2002, 09:32 PM
