Results 1 to 5 of 5
Thread: 2 Bluetooth Adapters 1 PC
    Feb 2011
    MD
    So my motherboard (Asus P8H67-I Deluxe) has an integrated blue tooth adapter. I am having a hell of a time getting Bluesoleil to function with it. Whenever I install Bluesoleil, the adapter won't make a connection. I uninstall, and the Asus BT Go software has no problem. At this point I'm fed up and considering just buy another adapter for $20 and calling it a day with the integrated 1. Is there any problem with this?
    Feb 2011
    MD
    Does anyone know if there is a list of BT devices compatible with Bluesoleil? Also, when running BS, is it supposed to shutdown all Win7 BT services and only run its own? I am beginning to think my problems are caused by BS drivers not supporting the integrated mobo BT device or that BS is colliding with windows and shutting down services it should not be (Bluetooth Support Service will not run with BS installed).
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    You should be able to disable the onboard bt in the bios. But there really shouldn't be a problem having both enabled/active...
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
    VegasGuy's Avatar
    May 2009
    Las Vegas
    You can run Bluesoliel and the Asus BT adapter/drivers, but you have to associate the Bluesoliel driver with a different BT dongle. BS will not work with the onboard device. There are no settings in Bios to disable the adapter, you just uninstall the Asus BT Go drivers. I have the same board and have used a Targus dongle (and BS) along with the Asus dongle.
    Cheers!
    VegasGuy
    Feb 2011
    MD
    Thanks, spent about 10hrs trying to get this working, was driving my nuts.
  1. Which Bluetooth adapters that work cell phones are recommended?
    By reapur in forum Wireless Communications
    Last Post: 10-16-2008, 09:09 PM
  2. Best HD Radio and Bluetooth adapters?
    By johnk in forum Centrafuse
    Last Post: 06-04-2008, 07:32 AM
  3. DIY DC>DC adapters? 19v, 12v, and 5v
    By netman86 in forum Power Supplies
    Last Post: 01-10-2007, 01:35 PM
  4. IDE-CF adapters
    By nadir_s in forum General Hardware Discussion
    Last Post: 09-24-2004, 02:32 PM
  5. R F adapters
    By SKIDrow in forum General MP3Car Discussion
    Last Post: 05-14-2001, 02:57 PM
