Results 1 to 6 of 6
Thread: What did I do to the carputer?? :(
    Sep 2010
    Hi all.
    I've somehow buggered the hardware of the car pc.
    All working find until I tried having a separate on/off button on the dash. No problems splicing the wires in the Mini ATX pc so that the normal power switch worked on the Antec ISK 300-65 case and on the button. But, as I tried to install the button I touch two wires together (NO, i hadn't disconnected the 2nd battery stupidly) and there was a spark. Now it won't boot up.
    The system can run on the normal 60w PSU off the mains or I've got a M2-ATX 160w psi. Both worked perfectly before, just needed to swap the cabling over for car or home use.
    The little light on the board lights up and I've checked all the wiring as much as I can and nothing happens whether I press the case power button or the separate on/off button.
    So my question is, what have I blown?? I've checked prices to replace the board and the case and as their not cheap I thought I'd ask here first.
    The spec is an Antec ISK300-65 case with 60w PSU (i think) or M2-ATX 160w PSU, Zotac NM10 motherboard.
    Help and thanks in advance.
    Whitey.
    Sep 2010
    Surely someone must have an idea please...
    Jan 2008
    have you tried it since blowing it on a ac/dc power supply? that would be the easiest way to see what works.
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Jan 2012
    WI
    How did you hook up the power switch? Did you run it in series with the original one off the psu or did you hook it up parallel to the psu's switch?
    Make sure you have it hooked up parallel to the other switch.
    Sent from my Evo 3D using Tapatalk.
    Jul 2011
    Ok, i'll give my two cents worth. If your getting a green light on the mobo, this would indicate that the psu is fine(in most cases). Did you try holding the on/off button on for more than say, 2seconds to see if it boots?
    Im not familiar with your particular mobo. But , does it( the motherboard)have its own Power button pins that would normally go to the front panel? If so, disconnect the ones coming from the psu/s and connect the power button switch directly to the pwr button pins on the mobo and try boot. Good luck mate.
    Constant Bitrate mayhembdm666's Avatar
    Mar 2008
    Adelaide, Australia
    As for why it is not booting, Well if you can rule out the power supply by knowing your benchtop one works then then i would start with the basics of reseating/resetting.
    Clear the bios, Reset memory and refit all connectors/plugs... My guess is the bios is jammed due to a bad boot or something.. I dont know if the 12dc PSU's use the old crowbar method....
    Do you mean PSU or mainboard?
    And stupid question, there is not a fuse that you have not replaced yet?
    2004 Holden WL Caprice Auto GENIII
    Base PC = Installed
    Front End = In Progress 75%
    OBD2 Interface = Installed / V2 Due Soon
    Realworld Interfaces = In Progress 20%
    Internet Linking = In Progress 10%
    Voice Control = In Progress 35%
  1. The Carputer is dead. -- Long live the Carputer!
    By Zoltan in forum General MP3Car Discussion
    Last Post: 06-23-2011, 09:31 PM
  2. Replies: 9
    Last Post: 08-07-2005, 12:27 PM
  3. Carputer article...: VeaLink CarPuter puts the media center on wheels
    By hd54321 in forum General Hardware Discussion
    Last Post: 03-21-2005, 01:26 PM
  4. Newbie asks ? Laptop based carputer vs desktop pc based carputer
    By SAScooby in forum General Hardware Discussion
    Last Post: 03-01-2004, 02:59 PM
