Results 1 to 7 of 7
Thread: climate control
    Feb 2012
    climate control
    Is there anyone that know how to run climate control off of the car pc. I will be running either the vintage air systems or pontiac fiero ac.
    I am building a lamborghini murceilago kit car. I want the pc to run everything like windows , door locks, etc. I am new to the forum. My name is Anthony Rodgers
    from Raleigh NC. I could not get help directly from mp3 or centrafuse so I am asking you guys.
    Last edited by mitchjs; 02-13-2012 at 11:45 AM. Reason: you dont want your phone # in a public post!
    MySQL Error
    Oct 2004
    short answer is yes... long answer is... first you need some sort of electrical interface from pc to clilmate controls...
    thats prob the hard part...then maybe a plugin written to talk to it all
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Feb 2012
    Do you know anyone that can do it.
    Variable Bitrate mayhembdm666's Avatar
    Mar 2008
    Adelaide, Australia
    Depending on the devices your wanting to run, then you will need to look at either some direct interfaces or an overall system/design.
    Have a search on the forums here for things like arduino and fusion brain. They should lead you to the interface side of things, As for the actual software control.
    Well that depends what GUI/FrontEnd you are running on the computer. Most Frontends will offer a plugin for controlling devices like the fusion brain or you have the option of creating your own plugin as well.
    Does the vehicle offer what you require via a direct interface also vs hardware interfacing..
    2004 Holden WL Caprice Auto GENIII
    Base System = Raspberry Pi
    Everything else is pending for now as switched from a Mini-ITX setup
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    it shouldn't be that hard to wire up the windows and door locks. relays for that.
    the climate control either take 3 servos (highish torque) as well as 2 additional relays. OR... you'll have to remove the climate control, but if the dials are just multiposition switches, then you'd just need more relays instead of the servos. (one relay for each position)
    EDIT: i was looking at the wrong climate control module. looks like you'll need 11 relays and then an actuator to move the temperature slider. -or- if you figure out that it's a simple potentiometer then you can replace that with an d/a coverter and use the arduino's pwm pin to control the temp
    the harder part is getting all that to work with the front end. i highly recommend using RR for this as has a very friendly learning curve. (from experience). arduino's are very fun and have a huge support community as well. the only thing that would be your hurdle would be how to get them to communicate. I know one member was starting to write a plugin for arduino with riderunner but im not sure where that ever ended up. (he has a free arduino from me... and i know he got some ways with it but hasn't completed it)
    arduino can send out serial commands. mitch can chime in on this one, but there may be a way for rr to take serial commands and either map them to keyboard presses or directly call execute a command w/i ride runner
    but... yeah it' doable.
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Banned
    Feb 2012
    I think that's awesome. Makes me feel layered. Like some sort of epic lasagna
    Mar 2008
    Adelaide, Australia
    Check if your aircons are using a resistor pack also, if thats the case then its even easier to do
  1. Replies: 225
    Last Post: 02-23-2013, 12:57 AM
  2. Climate Control
    By themlruts in forum Fusion Brain
    Last Post: 11-16-2010, 05:41 PM
  3. PC climate control?
    By daPyr0x in forum Hardware Development
    Last Post: 01-29-2006, 10:03 AM
  4. climate control
    By john_draws in forum General Hardware Discussion
    Last Post: 06-27-2004, 10:31 PM
  5. Climate Control
    By msumr282 in forum General MP3Car Discussion
    Last Post: 01-23-2004, 07:28 PM
