Results 1 to 10 of 11
Thread: Win 7 and hibernate
    Constant Bitrate Juliemac's Avatar
    Upstate NY
    Win 7 and hibernate
    Sorry if this is in the wrong forum, but I have run into a problem thats driving me nuts.
    System:
    PCB: Intel Atom D945CLF2
    HD Intel SSD 60 GB
    Power supply:M2-ATX 160 Watt Intelligent Power Supply
    OS: Windows 7 SP1.
    I have the OS set to hibernate on power button being pressed. I have Hybrid Sleep ste off so that I'll have the good old fashined hibernate. It does shut down but on restart I get a black & white screen stating it shut down incorrectly.
    Before upgrading the system, it did indeed hibernate correctly. Now its not.
    Any ideas guys?
    1981 VW Scirocco, 2L 16v turbo. EEEPC 1000 running Mega Squirt and music.
    Http://www.menloparkrandd.com/scirocco
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    "before upgrading the system"
    Upgrading drivers, software, hardware, what?
    Did you perhaps upgrade hardware without reinstalling the OS?
    Have you tried doing it without any USB devices plugged in at all?
    RevFE
    My Shop
    Upstate NY
    I had the SSD (SATA) and the rest of the set up running a pre-release copy of Win 7 Ultimate.
    Now, (wanting to be legal), I loaded a good copy of Win 7 and transferred it to a new case. EWvery thing works ok except the sutdown to hibernate. Could it take longer to shut down than the PS is allowing?
    I removed the external drive, the wireless and the touch screens (2x lilliputs)
    Jul 2011
    Sydney Australia
    Had a similar problem a long time ago. Due to installing a new os. I ended up fixing the problem by going into the bios and in the power menu i set System Suspend from "AUTO" to "S3". Maybe look into that.
    Upstate NY
    Great thanks!
    I'll check that out tonight when I get home.
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by Juliemac View Post
    Hibernate is almost instant in Win7. It's most likely that something is set wrong or you have a hardware issue that's hanging it up.
    Upstate NY
    Nope. I had that set already.
    I am trying to get the windows SDK so I can run xbootmgr.
    AARRGGHH
    Upstate NY
    The hardware really hasnt changed, but I am finding that the SP1 might be causing a problem.
    Hope its an easy fix, It has to be in the car by April and the good weather comes!
    Upstate NY
    Ok if I run the command prompt and enter shutdown -h, it will shut down and resume correctly.
    If I throw the power switch for the ATX power supply, it will shut down but reboot as resume does not function.
    Any other ideas guys?
    Upstate NY
    I tried this, but no help.
    <web>
    We have found that sometimes the BCD file may have issues.
    You can try this to fix the BCD file.
    1. Run CMD.EXE as administrator
    2. Run the following command: bcdedit -enum all
    Look for "Resume from Hibernate" in the output from the command above(example below):
    identifier {3d8d3081-33ac-11dc-9a41-806e6f6e6963}
    device partition=C:
    path \Windows\system32\winresume.exe
    description Windows Vista (TM) Enterprise (recovered)
    inherit {resumeloadersettings}
    filedevice partition=C:
    filepath \hiberfil.sys
    pae Yes
    debugoptionenabled No
    3. Once you have found it, copy the value for identifier (in this example - {3d8d3081-33ac-11dc-9a41-806e6f6e6963})
    4. Run the following command: bcdedit /deletevalue {3d8d3081-33ac-11dc-9a41-806e6f6e6963} inherit
    5. Test hibernation.
    </web>
  1. Replies: 2
    Last Post: 01-27-2011, 08:04 PM
  2. How to get PC to hibernate
    By hari-bhari in forum Centrafuse
    Last Post: 02-01-2007, 06:17 PM
  3. Won't hibernate
    By djmickyg in forum FrodoPlayer
    Last Post: 07-29-2004, 11:36 AM
  4. Which GPS will hibernate?
    By rgardjr in forum GPS
    Last Post: 01-23-2004, 03:48 AM
  5. Hibernate
    By HunterC4 in forum General Hardware Discussion
    Last Post: 02-07-2001, 08:05 AM
