Results 1 to 10 of 13
Thread: Cheaper option to the ESI Gigaport?
    Jan 2012
    As the title says is there a cheaper option to the ESI Gigaport that has quite a few inputs/outputs?
    Jan 2012
    Another options that may work, I have an M-Audio Firewire 410. It has 8 outputs and 2 inputs. Do you think I could use this? I'd have to get firewire onto my CarPC and also run a 12V connection to the box so it's not drawing power from the PC but it's something I already have?
    http://www.amazon.com/M-Audio-FireWi.../dp/B0000TP588
    Jan 2008
    does it need to be usb? the creative x-fi has been popular around here--i believe it only has 6 outputs though. and i don't like it's turn on pop..
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Jan 2012
    No, like I said I have a Firewire M-Audio sound card....I think I could probably use it as each of it's outputs show up independently. Having a hard time getting it installed on Windows 7 at the moment lol. Might be my firewire drivers though.
    Jan 2012
    Well.....I think I'm going to give the firewire card a try. Windows 7 doesn't like my desktops onboard firewire for some reason. I ordered a low profile 1394 PCI-E adapter that is based on the TI chipset for the CarPC so hopefully that'll fix my issues.
    Another thing I like about using the Firewire 410 is that I will have my phantom power mic pre built in right there.
    Jan 2012
    My Firewire 410 now works with the new firewire card. The only thing I'm not sure of is that I believe the software required to do the X-over stuff needs ASIO drivers correct? If so I may have to use ASIO4ALL or something as I don't think there are ASIO drivers for this device. Or maybe the ones from M-Audio are ASIO? I'm not sure.
    Edit: Ok nevermind it looks like the M-Audio drivers are ASIO compatible. So looks like I just need to gather the software now
    Jan 2008
    if you can swing it, i highly recommend audio mulch over console. i started with console, but found that has a lot of limitations, and is not as smooth as AM.
    HID retro--100%
    Jan 2012
    Quote Originally Posted by soundman98 View Post
    I don't know if I can swing Audio Mulch, that's quite a bit of money lol. Spending that much it didn't make sense to sell my MS-8. In what ways is console limited? I wish there was something built more for just being used as an active x-over for around 100 bucks lol.
    Also is there any way to do auto EQ and room correction on a PC?
    Jan 2012
    You know what, looks like there is a 60 day trial of AudioMulch, so maybe I can swing it within 2 months. 189 bucks for a 14 mb files....lol. In the demo description it says that after 60 days you just can't save documents or export or record sound files, do I need to do these things to setup my speakers?
    Jan 2008
    if you want it to run automatically in the car, then you do need to save the configuration files. i am not sure if this is included or not... at the very least, you can just mess with the configuration without saving-- you just need to re-do it every time..
    there are ways around this if you happen to know of the right place---wink-- that was how i got hooked on AM while using console
    my negative list:
    -console hasn't been updated since '08(last solid version since '07).
    -while i changed hardware when i made the swap, i believe the overall core of AM runs smoother with less required cpu power--great to allow for more plugins!
    -you can't run any more then a stereo pair of input's/outputs without using a program like asio4all. in AM, i don't need A4A-- i use the windows drivers directly.
    -inputs/outputs are shown in a list, not individual plugins, so if something changes-- like a usb card gets reidentified, the list numbering changes, but all the routing stays the same because the same numbers are in the list(i pulled my hair out a couple of times over this one)
    -and lastly, AM includes some nice plugins with it--most are centered around AM's original intent-- dj remixing and such, but some are still usable for car audio-- i ran the x-over's for a little while and still use the output level adjustment plugs for my tweeters. console doesn't include anything..
    both versions do offer a trial, so feel free to try before buying.
    and lastly, my how-to's on getting them setup:
    console:
    how-to: configuring console with vac and asio4all
    audiomulch:
    How To: Basic setup in AudioMulch
    i am not aware of any auto-eq's or room correction systems for the pc. as i am sure you already know, there are external processors that will do that.
    as far as the $100 remark.. let me find it..
    here-- the mini dsp:
    http://www.minidsp.com/
    the 2 channel variation hits the $100 mark exactly(without accounting for shipping). i haven't looked at it for a while, though i don't believe they do any auto correction either..
    HID retro--100%
  1. SOLD! - FS: ESI Gigaport USB Sound Card
    By RedGTiVR6 in forum Classifieds
    Last Post: 02-07-2009, 04:02 PM
  2. GIGAPort AG USB Sound Card
    By Linde in forum Car Audio
    Last Post: 04-20-2008, 11:20 AM
  3. GIGAPort AG
    By Dramey in forum MP3Car Products - store.mp3car.com
    Last Post: 11-27-2007, 07:31 PM
  4. GIGAPort AG issues
    By Dramey in forum Car Audio
    Last Post: 11-18-2007, 11:54 AM
  5. a cheaper power option
    By shakes in forum Power Supplies
    Last Post: 11-02-2003, 09:43 AM
