Results 1 to 5 of 5
Thread: Lilliput 629gl vga to hdmi
    Oct 2008
    Exclamation Lilliput 629gl vga to hdmi
    Good Evening,
    After a couple years of use, my DVI-I port on my motherboard is giving way. This is due to the tight quarters in which I have the carPC and it was bound to happen. Instead of repairing this port, the motherboard also has an HDMI out port. Can i use the following combination to go from the HDMI port to the vga on my Lilliput 629gl? It may seem like an excess of wires, but it would actually make life ALOT easier to get this beast in and out of the car.
    Thanks a million for the help!
    Intel DG45FC
    Very short hdmi cable(Hopefully I can find one under 1ft)
    to...
    http://www.meritline.com/female-dvi-...--p-30312.aspx
    DVI-I female to HDMI female
    to...
    http://www.meritline.com/male-dvi-i-...--p-30313.aspx
    DVI-male to VGA female
    to...
    Lilliput 629gl
    Over a year later I guess it's true...a carPC is NEVER complete
    2002 Mustang CarPC
    Jan 2012
    No, because you're still feeding a digital signal. You need an HDMI/DVI to VGA converter, not just a cable with both ends on it.
    Oct 2008
    Quote Originally Posted by Hdale85 View Post
    Great. Thank you.
    I will have to invest in one of the converters or have the motherboard replaced. I appreciate the response.
    2002 Mustang CarPC
    Apr 2012
    Milton Keynes in UK
    Can always replace the LCD controller in the Lilliput display, its cheaper than replacing your motherboard.
    Check out the make and no. of LCD display and look on NJYtouch site for a controller board, most have DVI and some even have HDMI inputs.
    You have to give them the model no. to get it properly programed.
    I'm sure that Lilliput use a good quality LCD in their monitor.
    Oct 2008
    Quote Originally Posted by simplyfred View Post
    I will absolutely follow up on this. The screen has given me nothing but problems lately. Do you know if these controller boards will fit in the stock casing?
    Thank you so much!
    2002 Mustang CarPC
  1. lilliput 669 hdmi rv
    By Kazimir in forum LCD/Display
    Last Post: 11-25-2011, 03:48 PM
  2. Hdmi out to VGA lilliput eby701
    By super-fly in forum LCD/Display
    Last Post: 08-05-2011, 09:44 AM
  3. Need lilliput HDMI/USB cable
    By phantomfsoc in forum LCD/Display
    Last Post: 02-15-2011, 08:07 PM
  4. Replies: 5
    Last Post: 03-30-2010, 05:42 PM
  5. Replies: 3
    Last Post: 03-15-2010, 09:31 AM
