Results 1 to 7 of 7
Thread: Using Morex 5689 Locking Mini-ITX Case With 60W PSU with PCI soundcard.
    kdl
    kdl is offline
    Mar 2012
    I an interested in this compact case but need help understanding how a PCI soundcard would fit in to this case?
    It does not look like it does, but that would mean any user would be stuck with the onboard sound device.. and who wants that. what are my options
    here is a link to the case http://store.mp3car.com/Morex_5689_L..._p/enc-035.htm
    Mar 2012
    Quote Originally Posted by kdl View Post
    If you want to use a PCI(-E) card, I would recommend this case:
    http://www.mo-co-so.com/Black-Box-PC...cs-bbm-pci.htm
    It is the one I just ordered. You have an option of ordering a Riser Card with it to install your PCI(-E) card into it. Chris also gives great customer service from my experience so far as well, prompt replys and quite helpful.
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    You won't fit a pci card in that case without heavy mods on your part, if at all. You would be better off with something like this case http://www.mo-co-so.com/Black-Box-PC...cs-bbm-pci.htm I think it comes with the flexible riser cable/card. Hope this helps SNO
    kdl
    kdl is offline
    Mar 2012
    that thing is huge. The setup has to find neatly into a mini cooper. I am going to a completely stock look, so it will need to be easily hidden
    Nov 2009
    Keswick,On Canada
    Then I would go with the first case and use USB sound card. Thats the route I went, a diamond 7.1 USB and it works great. SNO
    kdl
    kdl is offline
    Mar 2012
    Anyone ever dremel through the casing and use a PCIe extender to mount the soundcard on the side wall of the case directly under the HDD MOUNT?
    Nov 2009
    Keswick,On Canada
    Anything is possible! Just depends on how much work you want to do to achieve your goal. SNO
  1. Morex 5677 Mini-ITX Case in store - what PSU is included?
    By WhatsThePoint in forum Power Supplies
    Last Post: 05-22-2009, 03:52 PM
  2. FS: Morex Cubid 3688 Mini-ITX Case
    By ~*77*~ in forum Classified Archive
    Last Post: 10-16-2006, 03:54 PM
  3. WTB: Morex or Similiar Mini-Atx Case
    By A-Z in forum Classified Archive
    Last Post: 02-12-2006, 04:28 PM
  4. Morex 3688 Mini-ITX Case
    By blackbravo in forum Newbie
    Last Post: 04-19-2005, 07:36 PM
  5. FS: MOREX 3688 Mini-ITX Case
    By bklynkaos in forum Classified Archive
    Last Post: 08-15-2004, 11:18 PM
