Results 1 to 5 of 5
Thread: Am i pulling too much curent?
    Apr 2012
    Hi, i have a VW Urban Fox '06, i do not rightly know what the alternator is capable of, i have two amps in the car, a 150watt rms and 300watt rms, no caps.
    When the engine is off, the battery is at 12.5v, at idle it is 14.3ish v and when it is idling with the music as loud as i will ever play it(otherwise it is uncomfortable) the potential across battery+ and the chassis usually stays within 14.1-14.4v with the lowest it ever momentarily dropping to around 13.9v, am i pulling too much current from the system?
    I have also ordered some parts to assemble my car pc, consisting of a netbook that usually has a 90w charger(no battery installed, i think it will pull less current that way?)
    I am also going to buy a 7" lilliput.
    I know it is a small car but can anyone tell me what the signs are that i am drawing too much current or if i need a new alternator?
    Thanks!
    Elsewhere
    No, you're not pulling too much current.
    You'll know if you are when lights start dimming on hard bass hits.
    With the system you specified, I don't see that happening.
    How about the Wiki?
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Signs you are drawing too much: Your battery voltage steadily drops until the car shuts off. Most modern vehicle alternators can handle the kind of power you're using easily.
    RevFE
    My Shop
    Jan 2008
    if your really worried about it, install a volt meter in your car. with your car, i don't see any reason for worry until it drops below the 13.5v mark.
    Apr 2012
    Alright, thanks everyone for your replies!
    Sent from my HTC Sensation XL with Beats Audio X315e using Tapatalk
  1. pulling FD info from RR's SDK??
    By Nomader in forum Road Runner
    Last Post: 12-31-2006, 10:48 AM
  2. Pulling video off of a DVR
    By RedGTiVR6 in forum Off Topic
    Last Post: 02-04-2006, 08:27 AM
  3. Pulling the plug..
    By tj!2k4 in forum Off Topic
    Last Post: 12-13-2005, 08:05 AM
  4. Pulling 2.5 A with everything off??
    By dug1967 in forum Power Supplies
    Last Post: 01-07-2005, 12:16 PM
  5. Pulling a truck with your ****
    By Scouse Monkey in forum Off Topic
    Last Post: 10-23-2004, 12:50 AM
