Results 1 to 9 of 9
Thread: Running windows 7
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    Running windows 7
    I have an intel d510mo motherboard and will be pairing it with a intel SSD drive, can i safely install windows 7 with this with out suffering serve lag in performance. I have all versions of W7...basic, professional..etc etc.. and 2 GB of ram.... the D510MO is a dual core atom at 1.6GHZ..i have XP now with a normal HD but with an SSD I'd have to use w7 in order to take advantage of TRIM.
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    yes, you can safely. the lag you mention depends on what software you have running all at once.
    I run Win7 on all of my setups, including a single core atom.
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
    Aug 2007
    Queens, NYC
    just centrafuse... with garmin mobile
    CarPc
    Project "Driver"
    Planning [99.9%]
    Aug 2007
    Queens, NYC
    so should i install basic...professional...home?
    CarPc
    Project "Driver"
    Planning [99.9%]
    Mar 2004
    Greenacres, WA
    Quote Originally Posted by chris350 View Post
    I have used home and ultimate.
    See attachment for the guide I follow, don't remember if the login without password procedure is for Home or Pro/Ultimate, it's not the same.
    Attached Files Attached Files
    Aug 2007
    Queens, NYC
    should i expect to see significant differences with a SSD compared to a normal HD?
    CarPc
    Project "Driver"
    Planning [99.9%]
    Mar 2004
    Greenacres, WA
    Yes, the one system I have with an SSD is really responsive, and boots very quickly.
    I wouldn't build a new system without an SSD, at least for the boot/programs drive. Use an HDD to store all your media.
    Aug 2007
    Queens, NYC
    interesting...so i should use my 80GB SSD for just boot and programs and use a USB drive for media... good idea..
    CarPc
    Project "Driver"
    Planning [99.9%]
    Jun 2010
    I think you might want to stick with the Starter version of Win7 (you loose areo, but if you are running on a low end PC that is a good thing).
    The basic version I think is only available in emerging markets (I think).
    You could want to consider Home Premium if you want the media centre component (but if you are running something different, then that is irrelevant).
    Professional and Ultimate add other features you probably don't need (like the ability to join a domain, and run the IIS web server, so there will be more background services running by default).
    These links help decide:
    http://en.wikipedia.org/wiki/Windows_7_editions
    http://windows.microsoft.com/en-au/w...oducts/compare (second tab on this page is good for indervidual features, but it doesn't list starter)
  1. Running CF on Windows Fundamentals?
    By Lum in forum Centrafuse
    Last Post: 04-27-2007, 01:29 AM
  2. Hackers get Mac running Windows
    By ccsnet in forum MacCar
    Last Post: 03-18-2006, 11:08 AM
  3. Running windows with no services...
    By SFiorito in forum WinNT Based
    Last Post: 10-10-2005, 05:07 PM
  4. Running windows from a CD Rom
    By MP3Van2003 in forum General Hardware Discussion
    Last Post: 02-12-2003, 09:21 AM
  5. Running windows with no monitor?
    By BLACKOUT in forum General Hardware Discussion
    Last Post: 03-14-2001, 11:56 AM
