Height of Epia M10000
Does anyone know the height of the VIA Epia Nehemiah M10000? I know it's 17 cm x 17 cm, but what about the height?
Just over an inch and a half tall...probably closer to an inch and 3/4.
The audio in/out is the tallest item on the board by almost half an inch.
Probaby the 1 3/4 measurement is the better choice if you plan on using stand offs for the board.
1 and 37/64ths inches to be exact...not counting the solder bumps on the bottom of the mobo.
The mini-itx boards will fit in a 1U case which is 1.75" outside.
Raw Wave
I thought the HS on that thing was taller than the audio jacks???
Nope, the heat sinks are the same height as my memory...the audio out connector is about half an inch above that.
That is what is screwing up my install I have a flexy PCI extender but the audio jacks cause my video card to be too high....
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
