in CF, there is a file "HDRadio.xml"
find it, delete it
i've run into that same issue with the usb cable . it's something with when u set up centrafuse and if u unplug the cable for some reason the com port u used wont work any more . i rememebr i did something where i delete the setting for the hd radio and uninstalled the driver. then reinstalled the driver for the usb cable and then opened centrafuse so it can revonfig the hd radio . it was driving me nuts for a whole day because i know it worked 5 mins before then i had unplugged the cables. then poo no more radio . im gonna check it out on my pc to see what file it was .
find it, delete it
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
yea i think it's under c:\programdata\centrafuse\centrafuse auto\ "username" \
am i right on that ? it's been a while since i had to do that
yea... keep going, under radiomodules...
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
Current Vehicle: 2007 Dodge Nitro
Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
its not a huge issue all i did was just install my directed piece last . its something with centrafuse not autodetecting the com port .im not a programmer but i fiigured out that was the culprit since it worked fine with hd radio PCR. if it works fine with that then it had to be something with the centrafuse com port
CF is a bit of a mess...
delete that file, and it should look for comport
or, you can EDIT that file, to the right comport!!
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
ZOTAC G43ITX-A-E 2.5ghz Dual Core Celeron 2GB 160GB SSD
Win7 Ultimate - Remote Starter - Directed HD - Wifi
Garmin Mobile + MS GPS Puck - LTE WiFi Hotspot
2 Zones - Matrix Orbital LCD - Arduino - Build Pics
