In windows mixer are the level good or maybe muted by default? That was my problem when I could hear it click to turn on. That's all I got for you. SNO
I have a Directed DMHD-1000 that I hooked up with Mitch's serial adapter to a serial to usb adapter..
In Centrafuse when I select radio I can hear the radio clicking on but I get no sound nor am I able to scan channels..
Is there any other 3rd party program I can use to test or does anyone have any other ideas (sans attaching the display panel).
Current Vehicle: 2007 Dodge Nitro
Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
But I don't get any scanning ability for channels..
What about port settings in windows, are thay all set correctly, to match the unit and what is set in CF?
I don't even see any port settings in Centrafuse.. You just select HDRadio from the selection..
Sorry i was thinking of XM for the CF settings. But in windows for your usb dongle port is it set to 9600 i believe is the correct speed, But don't quote me on that. If that doesn't work I will go to my truck and verify the speed setting.
I stand corrected It runs at 115K Here is a link that might help you see if you get anything via terminal/hyperterm http://www2.dasilvas.info/hd-radio SNO
SatAmp4 on mitch's website, rush2112. That program would always work for me when trying to debug my usb/serial adapters and drivers for RideRunner, and those never worked for crap. Finally broke down and just ordered Mitch's USB cable,
TruckPC - gutted, being used for test setup
BoatPC - Update coming this spring
BlazerPC - PS keeps killing battery
I downloaded that SatAmp program but with no manual I must be a retard because I can't figure out anything in it!
Yea, I will if I have to (buy a USB one) but $40 is a bit steep IMO..
Oh I see you are not using mitch's complete cable. In your last setup did you use direct to serial port on computer, thats my prefered method but if you must use a dongle to convert to usb it needs to be ftdi chipset in the dongle. The prolific chipset is very wonky at best. SNO
