Results 1 to 10 of 11
Thread: wifi extension
    Dec 2007
    NY
    wifi extension
    So my wifi reception leaves A LOT to be desired. zotac mini. I bought an extended antenna 2.5X the size of the original, and the signal damn well nearly disappeared. I'm hoping someone has some simple insight to increase the signal reception.
    Elsewhere
    A higher power wifi adapter and/or antenna. The antenna should be an external antenna to prevent signals being blocked by the big metal box that is your vehicle body.
    How about the Wiki?
    Maximum Bitrate jmullan99's Avatar
    Feb 2009
    Niagara Falls, Ontario
    My carpc is in the trunk. I purchased an external antenna, ran the wire from the trunk to the rear window deck. Like DarquePervert said, the trunk is a big metal box that blocks a lot of signal. Up in the rear window the glass blocks a whole lot less signal.
    03 Cadillac CTS
    ZOTAC G43ITX-A-E 2.5ghz Core i3 2GB 160GB SSD
    Win7 Ultimate - OpenMobile - Directed HD - Wifi
    OMMaps + MS GPS Puck - WiFi via LTE Android phone
    2 Zones - Matrix Orbital LCD - Arduino - Build Pics
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I have my USB wifi stick in my rear brakelight housing.
    Which is at the bottom of my back window.
    Reception is pretty good, parked across the road from my house this morning and it picked up and connected to my home network no problem.
    That includes the drive plus my wireless hub is buried under the stairs.
    Jul 2010
    I have a usb wireless N-adapter mounted in my trunk area, almost resembles a normal jump drive in size. Now, I do have an suv with an open trunk area, but it picks up a lot of range. For example, I was sitting at a light, and picked up all the corner business' wifi and even the ones that were half a block back as well. Cost a year ago was prob like 25ish if even that. Maybe the onboard wifi adapter (even with new antenna) isn't cutting it. Just an opinion though!
    Current Worklog: TBA - '05 Rav4 (Mobo Dead).
    www.rav4world.com - Forums for Rav4 owners
    www.flavorfeasts.com - Cooking website/forums
    -Basic forums live atm, come contribute!
    Feb 2009
    To further define my in-car wifi: The carpc has the wifi antenna, which is just so the PC can a) connect to external (home) wifi when necessary. I have a 3G modem in the trunk. The 3G stick is also on the rear window deck. The router is also an access point for wifi in the car. This works fine. The signal from it does not go far beyond the car itself but every device in the car can connect to the network and have internet. It works quite well this way.
    03 Cadillac CTS
    Dec 2007
    NY
    OK, so pretty much I bought an extension that is no good. Because I wasn't really complaining that my extension can't pick up anything at a distance through the trunk, I was complaining that the thing actually killed my reception all together...router right beside the thing and reception is one bar with the extended antenna. So, can you guys just list the antennas/extensions that you have? I would prefer to just swap out the antenna, instead of getting a usb thing, but I will do whatever I need to at the end of the day.
    Feb 2009
    Not sure what kind of antenna / extension you mean. I have an external antenna that is about 8" tall, on a magnetic mounting base. I would not call it an "extension". Perhaps you mean just a wire with the standard little rubber antenna that comes on the back of some routers and PCs?
    I hope I didn't leave the impression that the 3G wifi router in the trunk does any good for connecting to the house network. It does fine for car interior.
    The remote antenna is connected directly to the carpc so it can connect to home wifi, and also connect to the router.
    If I can, I will take a pic of my antenna if that will help.
    03 Cadillac CTS
    Dec 2007
    NY
    This is the exact one I bought http://www.amazon.com/gp/product/B00...ls_o05_s00_i00. As soon as I put it on, the signal vanished.
    Feb 2009
    I'm going to guess that maybe it's a bad antenna. Can't tell from here.
    Do you have a router or something you can put it on and see if it works in that situation?
    This is more like what I use in the car:
    Wifi Antenna
    03 Cadillac CTS
  1. PCI Wifi adapter vs laptop wifi card (etc).
    By stonestatue in forum Wireless Communications
    Last Post: 08-03-2009, 12:42 PM
  2. Replies: 9
    Last Post: 12-21-2006, 10:18 PM
  3. Making your own wifi extension cable
    By Engram in forum Wireless Communications
    Last Post: 05-28-2005, 03:03 AM
  4. Replies: 1
    Last Post: 10-02-2004, 02:27 PM
