Results 1 to 10 of 13
Thread: Control circuit design review
    Dec 2011
    I'm starting work on my Car PC in a 2012 Honda CR-Z, and I've run into an issue that I thought would be common, but lots of searching hasn't found anything useful. The background here is that I want to have my reverse camera work even if the computer is off. So if I pull the PC out to work on it, or it breaks down, I'll still have rear visible. However, if the computer is up and running, I want the camera to be displaying through the PC so I can put an overlay on it and I want to have the camera powered at all times when the PC is running so I can record the video in case I am in an accident or something.
    Here is the logic:
    LCD Power is ON when the M4-ATX has power OR if I am in reverse
    LCD is showing Reverse camera (directly) if the PC is not yet ready AND I am in reverse
    Reverse camera has power if the PC is ready OR I am in reverse
    The blocks with 'NO' are Normally-Open relays, 'NC' is a Normally-Closed relay, and 'NO-10S' is a 10-second Delay-On, Normally-Open relay. I've omitted diodes, LEDs, and ground connections in the diagram. Input is on the left, Output on the right, and Control is either top or bottom.
    My crappy way of sensing the PC being ready is to use a time-delayed relay - eventually that will be replaced with a USB controlled NO-relay that is set/released on Windows startup/shutdown.
    Anyone have criticisms or recommendations? I'm not an electrical engineer, I'm a software engineer, so if it sucks don't be shy.
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    For the video side you just need a 1 to 2 composite splitter and power you could use the minibox picoUPS 100w along with a small SLA> Excuse the stick drawing, hopefully you get the idea behind the drawing. SNO
    Dec 2011
    I think you misunderstood - I'm looking to be able to use the backup camera when the car PC is completely turned off - for example if I disconnect it. For the video side, you're completely correct - I'll just split the signal. Things are more complicated on the power side. Here are the scenarios I'm thinking:
    1) Turn on car, LCD turns on immediately (shows BIOS, loading, etc), put in reverse immediately, PC not yet in Windows, I want the backup camera displayed on the LCD directly
    2) Driving down the street, I want to check my blind spot, press a button on PC, backup camera should be displayed on the PC
    3) Find a parking spot, put in reverse, PC is up, backup camera will be displayed on the PC
    4) If I pull the PC (and power supply) from the car and it's on the bench at home, driving around the LCD is off - if I put the car in reverse, LCD comes on viewing reverse camera
    Nov 2009
    Keswick,On Canada
    I have adjusted the drawing to show the power from computer is only to power the camera when PC is on. When pc is off the camera draws power from the sla. you should also put a couple of diodes in those lines from the computer. Hope that a little clearer as to what i was trying to show. Also thats not a power supply in my picture its a UPS type unit, here is the link http://store.mp3car.com/Mini_Box_pic..._p/pwr-040.htm
    Dec 2011
    OK, I see what you mean now, the "Computer" on the diagram isn't mean to be the computer, it's meant to be the power supply for the computer.
    The trouble I see is that the camera would be powered 24/7, whether the car was on or not, and whether or not the car is in reverse.
    Nov 2009
    Keswick,On Canada
    You could instead of using SLA just feed that from another line off ignition power that way when computer is on its feeding power on the left side of the UPS and if computer is off, the ignition power is feeding the right side of UPS and will shut camera off when key is turned off for the night. And only on when you are in the car. only 30 bucks to solve your problem as I see it. SNO
    Nov 2009
    Keswick,On Canada
    Thinking more about your goals why not feed the reverse light directly to the monitor trigger wire and power the camera off ignition line NO ups just direct feed when car is on camera is on and when you back -up the monitor will switch over to cam view and when you want to view camera while driving it will be on without out the need for reverse trigger to turn camera on. SNO
    Dec 2011
    Running the monitor trigger directly from the reverse light is something I considered (may do this as a 1st step while I build out the PC), but I want to be able to make an overlay - like the little curved lines showing where your wheels are headed, or integrated parking sensor information, automatic gamma/contrast correction, etc. Maybe even fish-eye distortion correction.
    Regarding the previous response - that's essentially what I'm doing with the relays. Just OR'ing the Reverse lights and PC-Ready lines, but two relays costs less than $10 and they are easy to replace locally. I'd have to do the same thing for the LCD power circuit and the trigger wire, too, so I'd be spending $90, whereas with relays I'm probably going to spend maybe $35. I expect to be able to have a control box with the relays, diodes, maybe an LED for the 'PC ready' line, fuses, linear regulators for the LCD & camera, and still be less than $100.
    Sep 2009
    i think you can accomplish 90% of this with one or two standard relays by using their normally-closed switches (and of course splitting the video signal too).
    but for clarification:
    - how does your monitor work, does it auto-switch to a rear-view video input whenever there is a signal there? or does it use a +12v trigger wire to switch to the rear-view video input?
    - for the goal "Find a parking spot, put in reverse, PC is up, backup camera will be displayed on the PC", how do you plan to trigger a software event when in reverse, are you using fusion brain, or joycon, etc?
    Dec 2011
    The monitor is a Lilliput 869 with the 12v trigger wire - should work exactly like the 669.
    I will be using a Joycon EXR (for now) for sensing when the car goes into reverse (this will be directly tied to the reverse lights).
    In the future, I will probably be buying/making a USB relay board with 12V inputs, and it will handle triggering the camera when the reverse lights come on and will replace the 10-Second Delay-On relay.
  1. Circuit Board Design
    By colin in forum Hardware Development
    Last Post: 07-26-2009, 09:00 PM
  2. circuit design
    By wantapc in forum General Hardware Discussion
    Last Post: 11-29-2008, 12:26 AM
  3. Circuit Design Help
    By bl3nd3r in forum Hardware Development
    Last Post: 06-22-2006, 03:56 PM
  4. Isolator Circuit Design
    By trebuchet03 in forum Power Supplies
    Last Post: 02-18-2006, 01:59 AM
  5. Circuit design software
    By phil.45 in forum Software & Software Development
    Last Post: 09-20-2002, 11:23 AM
