Results 1 to 10 of 13
Thread: Did you ever have problems with the Hdds due to bumps...?
    Jul 2003
    Hi,
    i'm looking into building a little carputer myself, but i was wondering if the bumpy rides wont make the harddrives go bad?? What are your experiences with that problem? And what workaround do you use?
    Thanks,
    Fluid
    Maximum Bitrate eugenen's Avatar
    May 2002
    Ohio
    Mine has survived several trips through the worst highways in the country (PA) and dirt roads of WV.
    Maximum Bitrate gizmomkr's Avatar
    Dec 2000
    Smyrna, Ga, USA
    I have had my setup for close to 4 years, my hard disk is mounted sideways. I have never had a problem. <fingers crossed>
    Gizmo-
    Techonlogy on Wheels
    http://www.hjnetworks.com/car
    Variable Bitrate spyhunter's Avatar
    Jul 2002
    central jersey
    i'm running around 4 years now, vertical mounted hard drives, no problems at all. i have run into cooling problems, insufficent power, but never because of bumpy roads
    Alex
    90 300zx twinturbo conversion
    Epia C3, 512 ram, syntax mobo, 80 gig WD, Mediacar, GPS w/Routis, all behind drivers seat, 7in Lcd Lilliput VGA with Touch, wireless adapter for stumbling, Consult ODB1 adapter and data scanner.
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    I have a 2.5" drive mounted just flat and no problems over new york tough roads, ...while the comp is running. Im gonna try the vertical mount just for a change.
    Mine needs to be updated.
    Dec 1999
    Buena Park, CA
    I just returned from a 2000+ mile round trip to Idaho. Hauling my travel trailer (6000#) over Interstate 15 in its various states of decay really let me know where each and every bump, hump, divot, flaky pavement and otherwise nasty piece of road is. I have a 4WD Dodge truck (solid axles front and rear), and my computer is mounted inside the front center jump seat (as shown in the attached photo). I just installed it there after upgrading the stereo system, so this was the first test. Prior to this, the computer case was mounted under my seat. This drive has held up well for a few years now (it was the same drive I used in Version 1 in my previous truck). I use a WD 45Gb drive, with two partitions (one system, one music).
    KG6OQD
    www.americansandassociation.org
    Mar 2003
    This is my first week with my carputer installed and was driving a lot today on I-15 on some really bad spots, there was one of those sections in the road that was graded so deep for paving that I actually came off my seat as the car dropped and made a really jarring bounce. I was worried for a second but the MP3 didn't miss a beat. Worst case is needing a new hard drive and as I have some major road trips planned I will be carring a couple spare drives with me.
    I have my system drive mounted vertically and my storage drive mounted flat.
    Dec 1999
    Buena Park, CA
    Moose, whereabouts on the I-15? I was on it from Nephi, UT to the California 60/I-15 exchange yesterday.
    KG6OQD
    Low Bitrate theedge's Avatar
    Apr 2003
    Vancouver, BC
    FYI a bump will never make the mp3 skip, due to the computer buffering several seconds of the mp3 into RAM. Much like anitshock on discmen.
    Mar 2003
    AV Geek - I was on it from Provo up to central SLC and all around the I-215 belt where they are just now in the middle of reconstruction, pretty bad road right now.
    theedge - I know I was just glad that the HDD didn't die. I wasn't expecting the MP3 to skip, I was expecting a big BSOD from a dead hard drive and my mp3car setup would "miss a beat" for a day or so. Bumps that hard would have made my head unit hiccup for a second, they really need to make head units with ESP for the offroad enthusiast
