Results 1 to 7 of 7
Thread: Laptop IDE Extensions
    Constant Bitrate captain_jim1's Avatar
    Nov 2002
    New Jersey
    Anyone have any idea where to find something like this? I want to relocate the DVD player in my laptop so that I can mount it in my custom console .. thanks!
    -Brad
    83 mp320i
    Nov 2002
    New Jersey
    no one? wow...
    -Brad
    83 mp320i
    99 mp323i
    _________
    7" Lilliput w/Touch, 150 W Opus, 2.4ghz P4 533fsb, 512 DDR 333mhz, GPS, WiFi Inet, 40g Maxtor 7200rpm, Laptop DVD/CD-RW w/USB2.0 Bridge, WinXP Pro.
    Aug 2002
    Eau Claire, Wi
    it would probably be easier to find some adapters so that you could use a regular IDE cable intead of the laptop connections
    System: AMD Duron 1200+ , 512 MB ram , usb sb mp3+ , Tview 7" touchscreen , M1-ATX PSU , Slot Load iMac DVD-Rom , 40 GB laptop HDD, netgear USB 802.11g
    Progress: Installation: 90% Dash fabrication: 80%
    Parts Needed: USB GPS
    Nov 2002
    New Jersey
    Regular IDE cables don't have the power line contained in them .. I was wondering if I got 2 of those 44pin to 40pin adapters . .and hooked the power lines together on them if that would work.. then all I would have to do is put a regular IDE cable in between them...
    -Brad
    83 mp320i 284k
    -Brad
    83 mp320i
    99 mp323i
    _________
    Newbie dieter's Avatar
    Jul 2003
    Norman
    Get several IDE cables and connect them with dual inline snappable headers (20-pin)
    Try digikey.com and search for part number WM6820-ND
    May 2003
    Does your laptop have USB2 or firewire??? If so then you could use a portable drive from Addonics. They also have one for CardBus / PCMCIA.
    Apr 2001
    NJ, USA
    Don't know if it'll do the trick, but Belkin makes round IDE extension cables now....think around 2'-3'. Seen'em in CompUSA, but they're not cheap...$20-$30.
    P4 2.4GHz, Intel mobo w/onboard sound & video, 128MB memory, 100GB Seagate Momentus laptop drive, Xenarc 700TSV 7" touchscreen, IRman using Girder, 150W Opus dc/dc psu, Alpine CDA-9835 h/u, MBQuart speakers, Infinity 15" sub, MTX amps.
