Is it possible that your power and/or ground lines are getting loose? I noticed some engine whine and hissing/static noise crept up on me. It would get worse when I ran over bumps... Could that be in?
Ryan
Without having changed anything, the reception on my radio unit is getting worse. PC and wiring locations have remained the same for 2 years.
I have a fender mounted antenna that I installed at that time. I have disassembled and cleaned it up (make sure ground and signal lines are good) and re-assembled. Doesn't help.
I also try the window antenna (with power applied as it has a booster) and reception is just as bad.
This has progressively gotten worse over many weeks and I cannot seem to figure it out.
Is there a known issue with Directed / Visteon radio units slowly dying?
Any and all help appreciated.
John
ZOTAC G43ITX-A-E 2.5ghz Dual Core Celeron 2GB 160GB SSD
Win7 Ultimate - Remote Starter - Directed HD - Wifi
Garmin Mobile + MS GPS Puck - LTE WiFi Hotspot
2 Zones - Matrix Orbital LCD - Arduino - Build Pics
Ryan
