Hi,
I'm going to hopefully starting the install this weekend, I just have a question about powering.
I'm going to hopefully be using the M4-ATX PSU from my old install (if it works). Using the PSU in the recommended settings (P1) and hook up power, ground and ignition as normal.
Then use the 5VSB from the 24 pin ATX to power the Joggler. This will turn on when ignition is on and turn off 60 seconds after ignition if off.
I don't think there is anyway of modding a power switch into the Joggler, so that will have to go without.
I think this is the best way to do it? If not, let me know =)
JM
