That should be more than enough for what you are planning to do. For those of us with more
power, we do so for the reasons of DSP.
For instance I did the same thing as you. I replaced my H/U SQ setup with a car PC and 8 output MAudio 1010LT.
I have the PC constantly running;
L crossovers
R crossovers
L parametric eq
R parametric eq
L delay
R delay
Anytime I am listening to
music I am at 10-12% constant CPU usage on a G530 CPU. Power consumption was very important, and I believe I am around 30w under load and less at idle, since my amps run around 30-50a @ 12v under load.
