Ok, the one whole row is cold when engine is off and hot when on so I could use any one of these.. Which would be best?
15A Fuel Pump
10A Starter A/T
10A A/T Cont
10A Injector
10A ABS Cont
15A O2 Sens
10A Washer MTR
Probably should be a 10A since the add a fuse is rated at that..
And the relays I have are:
YONG LIN
YL-314-C-12VDC
NO:40A/14VDC
NC:30A/14VDC
Again, I'd like to do this the easiest way possible with the least amount of wiring.. If it's possible with one relay I'd much rather!
LinkBack URL
About LinkBacks
