Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: Need help wiring a relay please..
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    I bought some LEDs that I want to install as daytime running lights on my car.. I want them to come on when the car is on but go off when the headlights are on..
    I would I wire this to accomplish that?
    Thanks!
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Mar 2011
    Ohio
    You could use two relays. Use the N.O. connection on one to turn on the DRL's when you turn on the key. Then use another relay in series with that, but use the N.C. connection and power that relay off the headlights.
    Oct 2003
    Poland, OH
    Any chance you could be more specific? Pin numbers and the like?
    Thanks much.
    Mar 2011
    Ohio
    http://www.autoshop101.com/forms/hweb2.pdf
    On the top of Page 9 shows a 5 pin relay, you would need two of those. They are usually good for 30A, and you can get sockets for them so they are easy to wire.
    Relay 1 DRL on (Normally Open Relay) Closes when power is applied
    Wire 86 to Ignition
    Wire 85 to Ground
    Wire 30 +12Vdc Power (Fused)
    Wire 87 Power out to Relay 2
    Relay 2 DRL off with headlights on (Normally Closed Relay) Opens when power is applied
    Wire 86 to a wire that goes hot when headlights are turned on.
    Wire 85 To Ground
    Wire 30 Power in From Relay 1's Wire 87
    Wire 87A out to DRL's + Wire
    On page 12 of the document they show Diodes to suppress the voltage spikes when turning off the relay, not a bad idea. A Radio Shack general purpose diode is fine. 1N4001 I think.
    Ground DRL's as normal.
    Is that a little more clear?
    May 2012
    Grandville, MI
    With standard automotive relays a Diode is not necessary since it is already included in the package.
    Also you CAN do this with one relay. The coil of the relay needs to see negative on one site and positive on the other side.
    Using a combination of resistors and possibly a Diode or two you can accomplish the same thing as using two relays. Also if you do use two relays you can use a standard 20/30 amp automotive relay to power the lights and a much smaller 12volt relay to control the coil when the lights are on or not since the second one really doesn't need to carry any current.
    Newbie daywalker03's Avatar
    Sep 2012
    Quote Originally Posted by redheadedrod View Post
    True; I also know that some newer vehicles use the existing lights (usually the high-beam at a lower intensity) to serve this function.
    Mar 2011
    Ohio
    As an alternative, you can use one heavy duty relay, and one light duty.
    Relay 1 DRL on (Normally Open Relay) Closes when power is applied. Heavy Duty Relay
    Wire 86 to Ignition
    Wire 85 to N.C. Of Relay 2
    Wire 87 Power out to Lights
    Relay 2 DRL off with headlights on (Normally Closed Relay) Opens when power is applied This can be like a 1 Amp Relay.
    Wire 85 To Ground
    Wire 30 Power in From Relay 1's Wire 85
    Wire 87A Ground
    How much current do your LED's Draw? Maybe you don't even need a really heavy duty relay. Some at Radio Shack are good for 10A.
    Lots of ways to skin this cat.
    Raw Wave
    Nov 2009
    Why not just connect the LED+ to IGN +12V, and connect LED- to headlight +12V.
    That's assuming halogen or similar headlight bulbs - the LEDs will ground thru the bulbs when they are off.
    Use one diode each for hi and low beams - ie, LED- into 2 diodes; diode-band towards hibeam +12V & lobeam +12V. If LEDs are under 1A, any 1N400x diode will do.
    No - very few relays come with inbuilt diodes. (My preference is plain relays with no inbuilt resistors or diodes. I then add diodes externally if required.)
    Oct 2009
    Couldn't you just use one relay, and not connect one of the pins?
    Basically, connect 30 to the ignition, 87a to the LEDs, 85 to the headlights, 86 to ground, and then just not connect 87 to anything? When the coil is activated, it should flip to 87, but since the LEDs aren't connected, they should turn off. Am I missing something?
    Raw Wave
    Nov 2009
    That should work noting that that if using the relay that redheadedrod described, you'd blow the fuse or the internal diode. (IE - hence the convention that 86 is more +ve than 85).
    But as I described, a relay probably isn't necessary.
  1. Relay wiring
    By cgalpin in forum FB Outputs
    Last Post: 07-04-2009, 05:52 PM
  2. 5v relay wiring help!
    By aalouie in forum General Hardware Discussion
    Last Post: 04-01-2008, 02:05 PM
  3. Relay Wiring Help
    By SKiTLz in forum General Hardware Discussion
    Last Post: 03-30-2008, 01:53 PM
  4. wiring a relay please help
    By 04scooby in forum Newbie
    Last Post: 01-30-2006, 11:56 PM
  5. relay wiring
    By nsmoller in forum General Hardware Discussion
    Last Post: 03-28-2005, 11:31 PM
