Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Heat shrink tubing- weather tight seal
  1. #11
    Aug 2011
    Quote Originally Posted by sebberry View Post
    Knew about them, but as I stated everything is crimped already and I already have a LOT of regular heat shrink so I would like to use some of it up before I go buying a bunch of adhesive lined tubing.
    I already decided on what I'm going to do, thanks for all the suggestions everyone.
  2. #12
    I use hot glue it reflows when you shrink the tube. About soldering connections- don't let the solder wick down the wire, the wire will get stiff and break.
    Chris Krug
    owner, turbine minivan
    http://www.youtube.com/krugtech
  3. #13
    GUS
    GUS is offline
    Low Bitrate GUS's Avatar
    Jan 2006
    Sweden
    I guess we are kind of doing the same thing, I have rebuilt a few harnesses for Mercedes and I use basically what has been suggested, heatshrink tube with heatglue on the inside, they do come in different thickness, thickest I use the tube material is about 2 mm after shrunk.
    If anyone is interested it can be followed here:
    http://longway.to/mbsl60072/
    And yes, it is a 7,2l V12....
    www.longway.to
    Mina bilar
    Roadtrip to Murmansk
    Roadtrip to Odessa
    20 cylinders, about 650 hk Mercedes
    MB 560SL -86
    MB SL600 -94
  1. to seal or not to seal an xenarc in a marine environment
    By scott_fx in forum General MP3Car Discussion
    Last Post: 03-02-2011, 08:51 PM
  2. best method tight or not tight
    By duncansri in forum Power Supplies
    Last Post: 07-23-2010, 06:09 PM
  3. Shrink wrapped package
    By fishypops in forum Newbie
    Last Post: 01-29-2010, 01:33 PM
  4. DVD Shrink Shutdown !!!!
    By dodgetimes2 in forum General MP3Car Discussion
    Last Post: 08-31-2005, 07:33 PM
  5. Tv card w/ am/fm tubing
    By em00guy in forum General Hardware Discussion
    Last Post: 04-20-2003, 11:44 PM
