Results 1 to 3 of 3
Thread: Options for integrating a carputer to aftermarket double-DIN touch-screen stereo?
    Oct 2005
    Southern Maryland
    Hi guys. I'm looking to get great sounding audio in my vehicle and have had great luck with getting the sound I want from Pioneer head units over the years. I'm not sure if I can expect the same quality and EQ adjustments in order to tweak the sound just as good with a carputer.
    I was thinking of for my next project installing a double-DIN touch-screen DVD receiver in my dash. What methods might I have for integrating a separate carputer into such a receiver and be able to control everything for the carputer via the touch-screen of the stereo receiver as well as integrate the audio and video of the carputer?
    I know something like the X2 Module will allow me to integrate a compatible Android smartphone with a stereo like this, but are their any options for integrating a carputer the same way?? Thanks!
    -Andrew
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    You can get equal or better audio quality from a PC as from a HU. It's definitely more work with the PC solution, but you gain added flexibility to configure your needs. If all you want is a clean audio source, then a HU wins IMO based on ease of install and cost.
    As far as using a DD HU to control the CarPC, to my knowledge everything out there in HU is proprietary and you will never be able to access an input on the touchscreen short of adding your own USB touchscreen film.
    Oct 2005
    Southern Maryland
    Thanks a bunch for the response Phil. This has me thinking to stick with the carputer route for my project. I appreciate your help!
  1. 2 Din Touch Screen options
    By pikie in forum Newbie
    Last Post: 02-27-2008, 10:39 AM
  2. Replies: 8
    Last Post: 02-05-2008, 06:46 PM
  3. Carputer setup options without touch screen
    By Outsider787 in forum General Hardware Discussion
    Last Post: 01-12-2007, 02:51 PM
  4. Fitting touch screen into double din stereo slot
    By Timmy C in forum LCD/Display
    Last Post: 04-08-2006, 04:44 PM
  5. Car Stereo and Touch screen together
    By eazyrog in forum LCD/Display
    Last Post: 10-22-2004, 03:52 AM
